Find Velocity of Mass in 12 Hours
  • Thread starter Thread starter Altoids
    Mass Velocity
The discussion focuses on calculating the velocity of a steel ball dropped from varying heights and its impact on a clay surface, based on an experiment inspired by Emilie Du Chatelet. The participants identified critical errors in their measurements, specifically mixing inches and feet, which compromised their data integrity. To rectify this, they must convert all measurements to feet and apply the formula v = √2gh to determine the velocity, where g is the acceleration due to gravity (9.81 m/s²) and h is the height. Subsequently, they will calculate the crater depth using d = v²t, ensuring the results align with theoretical expectations of a four-fold increase in depth.
  • Understanding of basic physics concepts, particularly gravitational acceleration.
  • Familiarity with measurement units, specifically the conversion between inches and feet.
  • Knowledge of kinematic equations, particularly v = √2gh and d = v²t.
  • Experience with experimental data analysis and error correction techniques.
  • Convert all measurements from inches to feet to ensure consistency.
  • Apply the formula v = √2gh to calculate the velocity of the steel ball for each height.
  • Use the formula d = v²t to determine the depth of each impact crater accurately.
  • Analyze the results to confirm whether the crater depths increase as expected and identify any remaining discrepancies.
This discussion is beneficial for physics students, educators conducting experiments, and anyone involved in data analysis related to motion and impact studies.
Altoids
Finding Velocity of Mass!
Hi!
This is a last resort for a project that has begun to go sour. We have a project due in roughly 12 hours comprised off of an experiment that Emilie Du Chatelet held. We are measuring the effects of height & velocity by dropping steel balls, at one foot intervals, into a one and a half inch thick piece of clay.
Then measuring the depth of the impact crater with a ruler and repeating the process eight times; corresponding to eight feet. Then timing the distance for the ball to fall to the related foot. (One foot, Two Foot, Etc..)
We’re analyzing the data and came upon a couple grave mistakes. We’ve accidentally measured with inches and feet. (Blame group projects). Overall, I believe our data is completely wrong, because in theory the depth should increase up to four times, but it hasn’t.
Any ideas how we can resurrect this in time? Our main man on the project just walked out the door in frustration.
Fortunately, there is still time to fix this project. The first step is to convert inches to feet and recalculate the velocity of the steel ball. To do this, you will need to use the formula v = √2gh, where v is the velocity, g is the acceleration due to gravity (9.81 m/s2), h is the height of the drop, and the √2 is a conversion factor. Once you have the velocity for each drop, you can then calculate the depth of each impact crater by using the formula d = v²t, where d is the depth of the crater, v is the velocity, and t is the time it took for the ball to fall. Finally, you can use this information to compare the depths of each of the impact craters and see if they increase four-fold as expected. Good luck!
  • · Replies 19 ·
