Easy circuit question but i get the wrong answer for PD
  • Thread starter Thread starter mr_coffee
    Circuit Pd
The discussion revolves around a circuit problem involving a car battery with a specified emf and internal resistance, focusing on the potential difference across its terminals during charging and discharging conditions.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • The original poster attempts to calculate the potential difference using the formula Vb - Va = E - Ir, leading to a result of 9V, which they believe to be incorrect. Other participants provide conflicting responses regarding the correct potential difference.
Participants are exploring different interpretations of the problem, particularly regarding the effects of charging versus discharging on the potential difference. Some guidance has been offered regarding the direction of current and potential drops, but no consensus has been reached.
There is a mention of the battery being charged with a specific current and the implications of internal resistance on the potential difference, which may not have been fully considered by all participants. The discussion reflects uncertainty about the application of the formula in different scenarios.
mr_coffee
Hello everyone! I am stuck on this simple problem...
A car battery with a 12 V emf and an internal resistance of 0.050 is being charged with a current of 60 A.
(a) What is the potential difference V across its terminals?
wrong check mark V
(b) What is the rate Pr of energy dissipation inside the battery?
W
(c) At what rate is electrical energy being converted to chemical energy?
W
(d) When the battery is used to supply 60 A to the starter motor, what is V?
V
(e) What is Pr in this case?
W
I found the V = 9V;
I drew the simple circuit then Used
Vb-Va = E-Ir;
V = 12v -60*.050 = 9V, but it was wrong, any ideas? thanks
pd = 12V
correct
pd = 12V
correct me if i am wrong
I found the V = 9V;
Vb-Va = E-Ir;
The car battery can be imagined as an ideal voltage source of emf 12 V and the internal resitance r=0.050 ohm connected in series. See the picture. A and B are the terminals of the battery, and X is the virtual junction of the virtual ideal source with the internal resistance.
The carging current flows into the battery to supply positive charges onto the positive electrode. It causes a potential drop of 0.05 * 60 = 3 V across the internal resistance. The potential drops along the direction of the current. So B is more positive than X. X is more positive than A. So the net potential difference across the terminals A, B of the real battery is 12+3=15 V during the process of charging.
Your formula is true when the battery supplies current to the starter motor. The direction of this current is reverse with respect to the charging current and the potential drops 3 V from X to B inside the battery. The terminal voltage is 9 V during discharge.
ehild
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 20 ·
