Finding the equation of a parabola
  • Thread starter Thread starter Flatland
    Parabola
The discussion centers around finding the equation of a parabola given its vertex and a point on the curve. The specific example involves a vertex at (-2, -2) and a point at (-1, 0).
  • Participants explore different methods to derive the equation, including using the vertex form of a parabola and the properties of derivatives at the vertex. Questions arise regarding the assumptions about the symmetry of the parabola and the implications of having multiple possible parabolas that fit the given conditions.
Several approaches have been suggested, with some participants providing specific equations based on the vertex form. There is an ongoing exploration of the implications of symmetry and the uniqueness of the solution based on the provided points.
Participants note the assumption that the parabola has a vertical line of symmetry, which influences the solutions being discussed. There is also mention of the potential for multiple parabolas satisfying the conditions if this assumption is not held.
Flatland
How do you find the equation of a parabola if you are given it's vertex and 1 point? For example, find the quadratic equation of a parabola that has a vertex of (-2,-2) and goes through the point (-1,0)
General quadratic equation: y=ax^2 + bx + c
Derivative: y' = 2ax + b
At the vertex, the derivate equals to zero. Use this fact and simultaneous equations to arrive at the equation.
More simply, since you are given the vertex of the parabola, you can write the equation y= a(x-x0)2+ y0 where x0 and y0 are the coordinates of the vertex. Choose a to force the parabola to go through the second point.
y= a(x-(-2))2- 2= a(x+2)2- 2. Setting x= -1, y= 0,
0= a(-1+2)2-2= a- 2 so a= 2.
By the way, this is assuming the parabola has a vertical line of symmetry. Otherwise there are an infinite number of parabolas satisfying these conditions.
Know your parabolas
HallsofIvy said:
... assuming the parabola has a vertical line of symmetry...
Graph first, and you may find a shortcut for a given specific data.
If a point on a parabola is 1 to the right and 2 up from its vertex, it must be parabola
[tex]y = 2x^{2}[/tex]
shifted horizontally and vertically, so its vertex (0,0) moves into (-2,-2), i.e. 2 to the left and 2 down:
[tex]y = 2(x+2)^{2} - 2[/tex]
  • · Replies 40 ·
9K
  • · Replies 44 ·
  • · Replies 30 ·
