Solving 3 Mass Pulley System: Acceleration & Tension Values
  • Thread starter Thread starter jamesbob
    Pulley
The discussion focuses on calculating the acceleration and tension values in a three-mass pulley system where all masses are equal (m1 = m2 = m3 = m). The user derived the acceleration to be 3.33 m/s² using the formula a = (m1 - m2)/(m1 + m2) * g, with g approximated as 10 m/s². The user is uncertain about the tension values T1 and T2, recognizing that T2 must be less than mg due to the system's acceleration, while T1 must be greater than mg. The conversation emphasizes the need for a systematic approach to derive tension values without specific mass values.
  • Understanding of Newton's laws of motion
  • Familiarity with tension in pulley systems
  • Basic algebra for manipulating equations
  • Knowledge of gravitational force calculations
  • Study the derivation of tension in multi-mass pulley systems
  • Learn about the dynamics of accelerating systems in physics
  • Explore the application of Newton's second law in tension calculations
  • Investigate the effects of varying mass values on acceleration and tension
Physics students, educators, and anyone interested in understanding dynamics and tension in mechanical systems, particularly in the context of pulley systems.
jamesbob
Three equal masses (m1=m2=m3=m)are hung over a pulley as shown*. Find the acceleration of the system and the values of the
tensions T1 and T2?
I got the tension to be 1/3*g (=3.33ms^-2) this is probably wrong, but I am more stuck on the acceleration. Any help would be much appreciated.
*shown is: a pulley system with two masses on the left side and one mass on the right. all masses are equal. T1 is the tension above the upper mass (m2) on the left side. T2 is the tension between the 2 masses on the left side (m1 and m2).
Assuming I am visualizing this correctly, two masses on the left falling down with gravity, and by virtue of the cable, they are pulling the mass on the right up, which is all subject to the pull of gravity.
Acceleration = F/m
In a static system, T2=mg, since the line between m1 and m2 would suspend the lower weight, m1. However, since the masses are accelerating, T2 < mg.
T1 > mg, since gravity is pulling on m3 and accelerating m3 at the same time.
Remember Tension is just a force.
Firstly thanks for your help so far. Sorry iv made a mistake in my first message. I got the Acceleration to be 3.3ms^-2 and I am stuck on the tension. Does that value for acceleration sound correct? I got it from doing:
a= (m1-m2)/(m1+m2)*g where in this case m1 is actually m1+m2 and m2 is m3.
m1=2m2 so m1-m2=2m2-m2=m2 and m1+m2=2m2+m2=3m2
so a = m2/3m2*g = 1/3*g = 3.33ms^-2 (taking g as 10ms^-2)
How can i get 'values' for the tension if i have no value for the mass? I'm guessing it will come from an equation where the masses cancel, but which equation? I know T=Ma or T-mg=-ma, any of them work?
  • · Replies 17 ·
  • · Replies 102 ·
9K
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 34 ·
