What are the partial derivatives of f(x,y) at (0,0)?
The discussion revolves around finding the partial derivatives of the function f(x,y) at the point (0,0). The function is defined piecewise, with a specific expression for points other than (0,0) and a value of zero at (0,0). Participants are exploring how to handle the function's definition and the implications of the denominator in the expression.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to simplify the function to address the division by zero issue. Some participants discuss the application of the quotient rule for differentiation. Others express uncertainty about how to compute the partial derivatives at the origin using the basic definition of partial derivatives.
Participants are actively engaging with the problem, with some providing hints and suggestions for approaches. There is a mix of attempts to clarify the process of differentiation and to simplify the function, but no consensus has been reached on the best method to proceed.
There is a hint mentioned regarding the simplification of the function, and participants are considering the implications of the function's definition at (0,0) versus other points. The challenge of dividing by zero is a central concern in the discussion.
Odyssey
Greetings, I need help in finding the partials with respect to x and y at (x,y) =/= (0,0) and (x,y) = (0,0)...
Let f(x,y) = { (xy^2-x^2y+3x^3-y^3) / (x^2+y^2) , (x,y) =/= (0,0)
{ 0 (x,y) = (0,0)
There was a hint given: first simplify f(x,y). I guess we have to get rid of the x^2+y^2 in the denominator to get rid of dividing by zero. But then I couldn't do it because of the "3" in the 3x^3.
Thanks for the help!
do you know the quotiant rule
[[g(x) * f'(x)] - [ f(x) * g'(x)]] / g(x)^2
yes...i differentiated with respect to x and y...but then I'm not sure how to find the partials of x and y at (0,0).
Use the basic definition.
[tex]f_x(0,0)= lim_{h\rightarrow0}\frac{f(0+h,0)- f(0,0)}{h}[/tex]
[tex]= lim_{h\rightarrow 0}\frac{\frac{3(h)^3}{(h)^2}}{h}[/tex].
[tex]f_x(0,0)= lim_{h\rightarrow0}\frac{f(0,0+h)- f(0,0)}{h}[/tex]
[tex]= lim_{h\rightarrow 0}\frac{\frac{-(h)^3}}{(h)^2}{h}[/tex].
That should be easy.
