Calculate the resistance at 18 Celsius
  • Thread starter Thread starter kEEhOLDEN
    celsius Resistance
The discussion focuses on calculating the resistance of a copper wire coil at two temperatures: 18 Celsius and 100 Celsius. The formula for resistance is established as R = ρ * L / A, where ρ is the resistivity of copper, L is the total length of the wire, and A is the cross-sectional area. Participants emphasize the importance of knowing the resistivity of copper and its temperature coefficient for accurate calculations. A recommended resource for finding this information is a specific online reference on copper resistivity.
  • Understanding of electrical resistance and its calculation
  • Knowledge of resistivity and temperature coefficient of materials
  • Familiarity with formulas involving length and cross-sectional area
  • Basic knowledge of copper wire specifications
  • Research the resistivity of copper at various temperatures
  • Learn how to calculate the cross-sectional area of a wire
  • Explore temperature coefficient of resistance for different materials
  • Study practical applications of resistance calculations in electrical engineering
Electrical engineers, physics students, and hobbyists involved in coil design or resistance calculations will benefit from this discussion.
kEEhOLDEN
cant do this question, well i can't figure out what I am supposed to do, whether its a thermistor or not, i worked out the inductance, but I am not sure what to do after that, here's the question
Calculate the resistance at 18 celsius of a 5cm diameter close-wound, single layer coil of 1000 turns of copper wire of 0.1mm diameter.
what would its approximate resistance be at a temperature of 100 celsius?
thanks
Doesn't sound like they want the inductance -- sounds like they are asking for the resistance of the coil at two different temperatures. You need the rho of copper, and it's tempco (temperature coefficient). The total resistance R = rho*L/A, where L = total length, and A = area (of the wire cross-section in your case).
If you have a chem table book or EE reference book handy, you can find the info in there. Or easier is to just google the following:
+copper +resistivity +temperature
and the first hit you get will give you what you need:
http://hypertextbook.com/facts/2004/BridgetRitter.shtml
BTW, I'm kind of a newbie to the PF forums, so I just learned recently that questions like this are supposed to be posted in the HW forums. So now I try to check out the HW question forums to see if I can be of help.
thanks that's very helpful, i jus joined the forums, that was my first post, so i haven't a clue what is going on in here anyways, cheers
  • · Replies 44 ·
9K
