Help with Ratios: Splitting 500 bucks
  • Thread starter Thread starter TSN79
    Ratios
The discussion revolves around splitting a total of 500 dollars between two individuals using different ratios, specifically 3/5 and 2/3. Participants are exploring how to correctly apply these ratios to determine the amounts each person should receive.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are questioning how to derive the amounts based on the given ratios and whether their interpretations of the ratios are correct. There is a focus on ensuring that the resulting values maintain the specified ratios when summed.
The discussion is active, with participants providing hints and questioning each other's understanding of ratios. Some guidance has been offered regarding the method to find the correct amounts, but there is still some confusion about the interpretation of ratios and their application.
Participants are discussing the need to ensure that the values derived from the ratios add up to the total of 500 dollars, and there is an emphasis on the correct mathematical representation of the ratios involved.
TSN79
Hi!
I have a supposedly simple question. Two people are splitting 500 bucks between them. First it will be split in a 3/5 ratio. Wouldn't the answer just be that one them gets 200 and the other gets 300? I think so.
So, following this last thought, if it is to be split in a 2/3 ratio, wouldn't one get 500*(2/3)=333,33 and then the rest (166,66) goes to the other one?
How did you arrive at your first answer? And for the numbers you gave, do they reveal a ratio of 3:5?
I'll add on to my post a little bit. For the first part, you are supposed to give two values that up to 500, and who's ratio's are 3:5. That means that once you get your two numbers, they should reduce down to 3/5.
How about looking at it like this?
[tex]x+y=500[/tex]
[tex]\frac{x}{y}=\frac{3}{5}[/tex]
Well, in the first case I take 500*(3/5)=300. And the rest (200) goes to the other guy. Apparently the answer to the second one is that they get 312,5 and 187,5. I don't get that.
Look at the above post for a hint. Once you understand the process, apply the same method to your second problem.
Hey thanks. So am I interpreting the concept of ratio wrong? Doesn't 3/5 mean that one is to get 3/5 of the sum, and the remaining 2/5 goes to the other?
It means that for every 3 parts of x, y will have 5 parts, where [tex]\frac{x}{y}=\frac{3}{5}[/tex]
Use the method I showed you in my first post to solve the question. You can't just multiply the sum by the ratio.
No, it doesn't. That's a "2 to 3" ratio. "3 to 5" ratio would be 3/8 and 5/8.
