Ow long does it take for the charge to build up to 9.0 µC? RC circuits
The discussion revolves around an RC circuit problem where participants are trying to determine the time it takes for a capacitor to charge to 9.0 µC given specific values for voltage, resistance, and capacitance.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the equation for charge in an RC circuit and attempt to solve for time using the natural logarithm. There are questions about the correct application of logarithmic properties and the interpretation of negative values in their calculations.
Some participants have provided guidance on manipulating the equations and taking logarithms correctly. There are indications of confusion regarding the calculations and the results, with some participants expressing uncertainty about their answers.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on ensuring the correct interpretation of the charge values and the time constant.
mr_coffee
Hello everyone, I almost got all the parts to this problem:
In an RC series circuit, = 11.0 V, R = 1.10 M, and C = 1.80 µF.
(a) Calculate the time constant.
1.98 s
(b) Find the maximum charge that will appear on the capacitor during charging.
19.8 µC
(c) How long does it take for the charge to build up to 9.0 µC?
s
I tried the following:
q(t) = Q[1-e^(-t/RC)]
q(t) = 9.0e-6[1-e^(-1.98)] = 7.75e-6s, which is wrong;
Since i know t = RC, and i found RC = 1.98, would it be
q(t) = 9.0e-6[1-e^(-1)] ?
I just tried this and its also wrong.
In your equation q(t) should equal 9.0mc since that is the charge that has built up after time t. and Q which is the total charge should be 19.8mc, then just solve for time.
thanks! I'm stuck on how I'm suppose to solve for t...
i have -(19.8E-6)(e^(-t/1.98));
do i take the natural log of both sides or somthing? but u can't take the natural log of a negative number!
you know that:
9.0E-6 = 19.8E-6[1-e^(-t/1.98)] = 19.8E-6 - 19.8E-6*e^(-t/1.98) so:
-10.8E-6 = -19.8E-6*e^(-t/1.98) /-1
10.8E-6 = 19.8E-6*e^(-t/1.98)
now you can take the natural log of both sides
Hey thanks for the responce!
I took the ln of both sides and got:
-11.44 = (-t/1.98)*ln(19.8E-6);
I end up with a negative number of -10.8, did I do this wrong? Sorry its been awhile since I did stuff with ln
you didn't take the natural logarithm of each side in the correct manner.
First divide through by 19.8*10^-6 to get rid of that term on the RHS of the expression.
So you would then have:
0.54 = e^(-t/1.98)
Take the natural log of that and you have:
ln(0.54) = -t/1.98
This will give you a positive number
Thanks! But i submitted that as my answer: t = .311 and it was also incorrect! hm...
ohh my bad hah thanks big man, it worked great!
9K
