Solvng Circuit Problems Involving R1, R2, R3, and R4
  • Thread starter Thread starter mr_coffee
    Circuit
The discussion revolves around solving circuit problems involving resistors R1, R2, R3, and R4, with given values and an ideal battery's emf. Participants are attempting to determine equivalent resistance and current through each resistor based on the circuit configuration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss methods for calculating equivalent resistance and current through resistors, questioning the arrangement of resistors in series and parallel. There are attempts to apply Ohm's Law and clarify the relationships between the resistors and the battery.
Some participants have provided guidance on finding equivalent resistance and calculating current, while others are exploring different interpretations of the circuit setup. There is a mix of correct and incorrect calculations being shared, with ongoing questions about voltage and current relationships.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. Some are expressing confusion about the calculations and the implications of their results.
mr_coffee
Hello everyone, I'm confused on what I'm suppose to do here...the problem says:
R1 = 100 . R2 = R3 = 45.0 . R4 = 75.0 , and the ideal battery has emf = 6.00 V.
Here is the image:
http://www.webassign.net/hrw/27-42.gif
Here is the question:
(a) What is the equivalent resistance?
117.31
(b) What is i in R1?
.051
(c) What is i in R2?
(d) What is i in R3?
A
(e) What is i in R4?
A
Okay i got (a) and (b), but messed up (c) like a lot of times...
I tred i = E/R1+R2, i = .051, and a few others, all wrong...any ideas what I'm doing wrong?
r1 is not in series with r2 so your method can't work. r2, r3 and r4 are in parallel, find the equivalent resistance, r_eq1.
now, r_eq1 is in series with r1, so you can find the voltage through r_eq1 which is the same as r2,r3 and r4 since they are parallel.
have the value of r and the voltage, then use Ohm's Law to find the individual current.
Hey thanks for the reply! So your saying, find the rquivalent resistance of r2,r3, and r4? I did that and got 225/13, I knew R1, so i added r1+225/13 = 117.31, and i found the current through R1, = .051, you talk about finding the voltage through R1_eq1, R = V/i, so i = V/R, i = 6/R2? i = 6/45 = .23333 amps for the current through R2, like that?
sorry, actually you don;t need to find r_eq1 since you know i1=0.51 A already.
the voltage across r_eq1 = 6-i1*r1.
this voltage is the same for r2,r3 and r4 which are parallel.
you know their resistances and the voltage, use ohm's law afterwards.
thank you! But i get a negative voltage r_eq1 = 6-.51*100 = -54, is that okay?
i didn't check the anwers for the first 2 parts.
r_eq of the circuit = r1+255/13 = 100 +255/13=119.6 ohm.
i_r1= v_battery/r_eq = 6/119.6 = 0.0502 A. : after finding the r_eq1 for r2,r3,r4, you now get a series circuit consists of r1 and r_eq1.
  • · Replies 31 ·
9K
  • · Replies 16 ·
