| Thread Closed |
Using a mac |
Share Thread | Thread Tools |
| Oct29-05, 02:19 PM | #18 |
Using a macAnyway, I bought a eenie teenie tiny mouse for 12 euros that looks really nice and works well too
| Oct29-05, 02:27 PM | #19 |
| Oct29-05, 02:57 PM | #20 |
I got this mouse http://www.sweex.com/product.asp?pid=469 from sweex, with retractrable cord. It looks VERY sleek!! The scroll button has a blue led underneath, so it lights up blue and the whole thing is matt black rubber, with the silver lining/dots. It moves very easily over the desk, there is little resistant and lies good in the hand. I love it, my bf can't keep his hands off it too
Also, when I hold it up from the desk the red led underneath starts flashing: a real disco mouse I tried another small mouse (a pretty green one), but the shape wasn't as ergonomic as this one.I also looked for a mac mouse, but those things are 55 euros (how do I make the euro sign under the two appear?) and you only get one button
| Oct29-05, 03:31 PM | #21 |
| Nov1-05, 02:31 PM | #22 |
I recently started using a mac too and yeah the latency of the track pad drove me nuts!! It took forever to move from one edge of the screen to the other. But I eventually found an add on that fixes that. MouseZoom Upon installation, it adds an option in 'System Preferences' called MouseZoom. You can get to 'System Preferences' from the Dock. And it lets you adjust how fast you want the mouse pointer to move. |
| Nov1-05, 02:35 PM | #23 |
But I do like Adium! It lets me connect to all the different IM services in the one program and looks real sleek too! |
| Nov5-05, 04:24 PM | #24 |
Just saw this thread I'v been busy doing my uni applications recently, did everyone sort out all there problems? I'll read it all tommorow and post some advice.
| Nov7-05, 03:13 PM | #25 |
Is it still crashing often?, is it just freezing or is it a kernel panic? (a semi-transparent grey screen with "you need to restart" (or word to that effect). If it is the latter and it happens often once a day or more it may be your RAM so find the hardware test disk that came with your machine and follow the instructions on it to test the RAM. If anything is wrong ring apple and get a replacement machine. When you download an application (a free one usually has this form of installation) you need to load up the file you download (icon will look like a hard-drive), this will create a temporary drive in the finder, just under "Macintosh HD", but what you need to do is drag the contents of this volume onto your applications folder and it will copy it to there (make a folder in there for each application to keep it tidy). Then eject the volume and delete file you downloaded. Some applications do have installers like on windows but these are normally applications to be installed from disks you purchased. No applications on OS X have uninstall file you just have to put it in the trash and then empty the trash to do this, some preferences files will remain but you can search for them in spotlight and delete them if you wish. More to come. |
| Nov7-05, 03:57 PM | #26 |
For the track pad I would use the MouseZoom application posted by crumbles above.
I had a look around for a way to do it without any third party applications and found this. You'll need to use the Terminal for this, as well as the Property List Editor tool that's part of XCode. The setting is inside this file: "~/Library/Preferences/.GlobalPreferences.plist" (without the quotes). You'll need to make that file visible by copying it (using the cp command - cp source destination) to a filename without a period in front of it (I used test.plist). Then, drag that test.plist file to Property List Editor (found in /Developer/Applications/Utilities) and look for a setting called com.apple.mouse.scaling. Its normal maximum value is 3.000000 - change that to something bigger. Save the edited file, then go back into Terminal and use cp again to replace the original .GlobalPreferences.plist file with the edited one. Once that's done, log out and back in for the change to take effect. This will provide you with a faster trackpad if you put a large number in above. |
| Thread Closed |
| Thread Tools | |
