How to tell difference between Hot-rolled steel and col-rolled steel
  • Thread starter Thread starter zwwzli
    Difference Steel
The discussion focuses on distinguishing between hot-rolled steel and cold-rolled steel. Key identifiers include the surface texture, with hot-rolled steel exhibiting a rougher surface compared to the smoother finish of cold-rolled steel. Additionally, any steel sheet that is 3/16" or thicker is definitively hot-rolled, as cold-rolled sheets do not exceed this thickness. The likelihood of rust on hot-rolled steel further aids in identification.
  • Understanding of steel manufacturing processes
  • Familiarity with steel sheet thickness measurements
  • Knowledge of surface finish characteristics
  • Basic concepts of material properties and corrosion
  • Research the properties of hot-rolled vs. cold-rolled steel
  • Learn about the applications of different steel types in construction
  • Explore methods for testing steel surface finishes
  • Investigate the impact of thickness on steel performance
Manufacturing engineers, quality control inspectors, and materials scientists who need to identify and differentiate between hot-rolled and cold-rolled steel for various applications.
zwwzli
I am assigned a job to check some materials of steel sheet.
Is there anyone here can help me to tell it by just looking?
I know hot-rolled has rougher surface than cold, but anthing else?
Thank you so mcuh!
That's the surest way of telling (and usually, hot-rolled steel is more likely to have rusted). Also, no sheet that's 3/16" or thicker (roughly thicker than gauge 7) can be a cold-rolled sheet.
thank you Gokul 43201.
9K
20K
