Thread Closed
Angular Velocity Problem
Share Thread
Oct27-05, 09:13 PM   #1
I'm having problems with parts b and c...
At time t= 0 a grinding wheel has an angular velocity of 22.0 rad/s . It has a constant angular acceleration of 26.0 rad/s^2 until a circuit breaker trips at time t= 2.30 s . From then on, the wheel turns through an angle of 436 rad as it coasts to a stop at constant angular deceleration.
a. Through what total angle did the wheel turn between and the time it stopped?
Express your answer in radians.
[tex]\Delta \Theta = 13t^2 + 22t [/tex] at t=2.3s is 119.4rad
Therefore total angle is 119 + 436 = 555rad
b. At what time does the wheel stop?
Express your answer in seconds.
So I know that [tex] \omega_{f} = 0 [/tex] for the wheel to stop
[tex] \omega_{i} = 22.0 rad/s [/tex]
That's as much as I understand...
c. What was the wheel's angular acceleration as it slowed down?
Express your answer in radians per second per second.
Would I use this equation [tex] \omega_{f} = \omega_{i} + \alpha t [/tex]
and just solve for [tex]\alpha[/tex]?
\omega_{i} = 22.0
t = time solved in part b [\tex]
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct28-05, 06:10 AM   #2
Recognitions:
Homework Helper Homework Help
b)
Supposing I understood the problem right (I'm unfamiliar with the term grinding wheel):
The equations for constant acceleration are quite similar to the ones in kinematics.
[tex]\omega = \omega _0 + \alpha t[/tex]
[tex]\theta = \theta _0 + \omega _0 t + \frac{1}{2} \alpha t^2[/tex]
Now with two equations and two unknowns, can you solve for [itex]t[/itex] ?
Thread Closed
Similar discussions for: Angular Velocity Problem
Thread Forum Replies
Angular Velocity Problem Introductory Physics Homework 4
Angular Velocity problem Introductory Physics Homework 3
Angular velocity problem Introductory Physics Homework 1
Angular Velocity Problem Advanced Physics Homework 0
Angular velocity problem Introductory Physics Homework 3
