Calculate Air Flow Force for Piping System Setup
The discussion revolves around calculating the force exerted on a block by air flowing through holes in a piping system. Participants explore the applicability of Bernoulli's equation and conservation of mass in this context, focusing on fluid mechanics principles.
  • One participant questions how to calculate the force on the block and whether Bernoulli's equation is applicable.
  • Another participant asserts that Bernoulli's equation and conservation of mass should apply, suggesting that mass in equals mass out.
  • A different participant presents a mass flow equation involving multiple inlets and an outlet, noting the unknown velocities and pressures, and questions how to solve for the force on the block.
  • One participant advises starting at the node where the pipes meet and applying the continuity equation to determine flow rates, then using Bernoulli's equation to calculate pressure drops.
  • A participant seeks clarification on whether the "force on the block" refers to a lower pressure that would "suck" on the block, confirming that this is indeed the case.
Participants express varying approaches to the problem, with no consensus on a single method or solution. Multiple competing views on how to apply fluid mechanics principles remain evident.
Participants note assumptions such as atmospheric pressure at the inlets and highlight the challenge of having more unknowns than equations in the presented scenario.
bigdads
See attachment for piping system setup.
Question: How much FORCE will the block feel from the air flowing through the two holes in the lower pipe?
I have no idea how to calculate this. Does Bernoulli's equation apply anywhere here?
it looks just like a problem straight out of my fluid mechanics textbook
bernoulli's should apply
and conservation of masses
mass of all inputs - mass of output = total mass change in the system
and for this system
mass in = mass out
So you have 4 inlets & 1 outlet...
Conservation of mass??:
A1v1+A2v2+A3v3+A4v4 = A5v5
unknowns: v1, v2, v3, v4
A=area
v=velocity
Bernoulli??:
P1+P2+P3+P4+(1/2)p(v1^2+v2^2+v3^2+v4^2)+pg(z1+z2+z3+z4) = P5+(1/2)p(v5^2)+pg(z5)
P=pressure
v = velocity
p = density
g = acceleration due to gravity
z = height
Assumptions: P1=P2=P3=P4=atmospheric pressure
2 equations, 4 unknowns...How can this be solved?
How can I use this to get the force on the block?
You're not going to be able to cover the entire network in one swoop. Start at the node where the two pipes meet and apply the continuity equation: [tex]Q = Q_1 + Q_2[/tex] where the total flow is the flow from the fan. That will give you the two flow rates (a function of the diameters). Now that you have the flow rate at that node, you can now go to Bernoulli and continue back up the pipe to calculate the pressure drop around those holes.
Just out of curiosity, when you say "force on the block" you are referring to a lower pressure that will (I hate to use this term) "suck" on the block? In other words, you want to know if you'll have enough flow to pick up the block?
Yes
  • · Replies 56 ·
  • · Replies 16 ·
