Volume of the solid enclosed by the paraboloids
  • Thread starter Thread starter Whatupdoc
    Solid Volume
The volume of the solid enclosed by the paraboloids defined by the equations z = 16(x² + y²) and z = 32 - 16(x² + y²) can be calculated using cylindrical coordinates. The x bounds are established as -1 to 1, while the y bounds are from -√(1 - x²) to √(1 - x²). The z bounds are given by the equations of the paraboloids. The final volume integral is expressed as ∫ from r=0 to 1, ∫ from θ=0 to 2π, and ∫ from z=16r² to 32-16r², simplifying the calculation through the use of circular symmetry.
  • Understanding of triple integrals in calculus
  • Familiarity with cylindrical coordinates
  • Knowledge of paraboloid equations
  • Ability to perform integration in multiple dimensions
  • Study the application of cylindrical coordinates in volume calculations
  • Learn about the properties of paraboloids and their intersections
  • Practice solving triple integrals with varying bounds
  • Explore advanced integration techniques in multivariable calculus
Students and professionals in mathematics, particularly those focusing on calculus, geometry, and volume calculations, as well as educators teaching multivariable calculus concepts.
Whatupdoc
Find the volume of the solid enclosed by the paraboloids z= 16(x^2 +y^2) and z=32-16(x^2+y^2)
i'm not sure how i would find the x bounds for this triple integral. here's my work:
16x^2+16y^2 = 32-16x^2+16y^2 => simplifies to y = +- sqrt(1-x^2) (the y-bounds)
z bounds is already given which is from z= 16x^2+16y^2 to 32-16x^2+16y^2
but how would i find the x bounds (mathematically if possible)? I'm not sure
I would try a different coordinate system?
Adding the two equations gives 2z= 32 or z= 16. When z= 16 both equations reduce to x^2+ y^2= 1 so you are correct. x ranges from -1 to 1, for each x, y ranges from [itex]-\sqrt{1-x^2}[/itex] to [itex]\sqrt{1-x^2}[/itex], for each x,y, z ranges from 16(x2+ y[/sup]2[/sup]) to
32- 16(x2+ y2.
The volume is
[tex]\int_{x= -1}^1 \int{y=-\sqrt{1-x^2}}^{\sqrt{1-x^2}}\int_{z=16(x^2+ y^2)}^{32-16(x^2+ y^2} dzdydx[/tex]
Yes, you would find it simpler to take advantage of the circular symmetry by changing to cylindrical coordinates: r, [itex]\theta[/itex], z.
The largest extent parallel to the xy-plane is at the intersection of the two parabolas, a circle with radius 1 so r ranges from 0 to 1, [itex]\theta[/itex] varies from 0 to [itex]2\pi[/tex] and z varies from 16r<sup>2</sup> to 32- 16r<sup>2</sup>. <br /> The volume is <br /> [tex]\int_{r=0}^1 \int_{\theta=0}^{2\pi} \int_{z= 15r^2}^1 r dzd\thetadr[/tex].[/itex]
  • · Replies 34 ·
