Application of Ampère-Maxwell equ.
  • Context: Graduate
  • Thread starter Thread starter quasar987
    Application
The discussion revolves around the application of the Ampère-Maxwell law in the context of a capacitor with varying electric fields. Participants explore the conditions under which the magnetic field can be considered constant along a path of integration, particularly focusing on symmetry arguments and comparisons to established laws like Biot-Savart.
  • One participant presents a scenario involving a capacitor and a time-varying electric field, questioning the justification for assuming the magnetic field is solenoidal and constant along the integration path.
  • Another participant suggests that cylindrical symmetry allows for the assumption of a constant magnitude of the magnetic field around the loop, but expresses confusion about the relevance of the right-hand thumb rule and Biot-Savart law in this context.
  • A further contribution clarifies that the right-hand thumb rule is used to verify the direction of the magnetic field, while symmetry arguments justify its constant magnitude along the contour.
  • Participants discuss the conditions needed to apply the Ampère-Maxwell law, specifically the need for the magnetic field to be constant in magnitude and tangent to the amperian circle.
  • One participant expresses uncertainty about how to derive the magnetic field from a changing electric field, indicating a lack of an equivalent to the Biot-Savart law for this scenario.
There is no consensus on the justification for the assumptions regarding the magnetic field in the context of the problem. Participants express differing views on the relevance of symmetry arguments and established laws, indicating ongoing debate.
Participants note the absence of a clear equation relating the magnetic field to the changing electric field, which complicates the discussion. The reliance on symmetry and established laws is acknowledged, but specific mathematical relationships remain unresolved.
quasar987
Consider the set-up illustrated in the attachement. The radius of the capacitor plates is a. The field btw the plates varies according to
[tex]\vec{E}(t) = \frac{It}{\epsilon_0 \pi a^2}\hat{z}[/tex]
(z is to the right)
So since the current enclosed is 0, Ampere-Maxwell law in its integral form after evaluation of the integral of [itex]d\Phi_E/dt[/itex] reads...
[tex]\oint \vec{B}\cdot d\vec{l} = \mu_0 I \frac{s^2}{a^2}[/tex]
s being the radius of my amperian loop.
What is the argument according to which B is solenoid and constant along the path of integration? In the case of magnetostatic, it was the right-hand thumb rule (i.e. the Biot-Savart law) that allowed us to determine the orientation of B. But now what is it that permits to conclude?
Looks like I forgot to add the picture doesn't it.
I'm not really sure I understand what you want to know (what do you mean exactly when saying "What is the argument according to which B is solenoid and constant along the path of integration?"), but I'll just suppose you want to know why you can assume the magnitude of the B-field to be the same around your loop. The answer is: a symmetry argument (cylindrical symmetry).
But then I don't get what you're talking about "right-hand thumb rule" and "Biot-Savart". This has nothing to do with assuming the magnitude of the B-field to be constant along your loop.
Hoping to get some clearer input next time...Cliowa
In the case of say a straight current wire in which a current I circulates, what allows you to conclude that the field is in the chape of concentric circles around the wire and constant in magnitude on the contour of each circles? It is the Biot-Savart law, which tells you B is in the direction of
[tex]\vec{I} \times \frac{\vec{r}-\vec{r}'}{|\vec{r}-\vec{r}'|}[/tex]
(using Griffith'Ssnotation). This is the "right-hand thumb rule": let your thumb point in the direction of I; then your fingers curl in the direction of B.
In order to say that
[tex]\oint \vec{B}\cdot d\vec{l} =B2\pi s[/tex]
one must show that
i) B is constant in magnitude on the contour of the amperian circle.
ii) B is tangent to the amperian circle (so the dot product has no [itex]\cos\theta[/itex] term)
The "right-hand thumb rule" is used to verify the property ii).
Also in the case of the straight current wire, B is constant in magnitude on the contour by a simple symetry argument: Consider a point anywhere is space. Now rotate the wire along its axis or make the point travel along a circular path centered on the wire: nothing changes AT ALL. Hence the field has no choice but to be the same everywhere along the circular path.
I have strong reasons to believe that in the case of the magnetic field of my problem, B also satisfies the conditions i) and ii). But I don't have an equation for [itex]\vec{B}[/itex] in terms of dE/dt (i.e. the equivalent of Biot-Savart). So how do I know what the B field created by a chnaging electric field looks like?
I can see why it is constant along the amperian circle though.
  • · Replies 21 ·
