Display a cylindrical surface in 3D using gnuplot
The discussion focuses on how to display a cylindrical surface and a vertical plane in 3D using gnuplot. Participants explore commands and expressions relevant to visualizing these geometric shapes.
  • Homework-related
  • One participant expresses difficulty in using gnuplot to display a cylindrical surface defined by the equation x² + y² = 1.
  • Another participant suggests using the splot command but provides an example that does not pertain to a cylinder or vertical surface.
  • A later reply clarifies that while the provided example creates a surface, it does not meet the criteria for a vertical surface or cylinder.
  • One participant discovers that using the "set parametric" command allows for the creation of parametric expressions for the x, y, and z coordinates to achieve the desired display.
Participants do not reach a consensus on the specific gnuplot expressions needed for displaying a cylindrical surface or vertical plane, and multiple approaches are discussed without resolution.
Limitations include the lack of specific gnuplot expressions for the cylindrical surface and vertical plane, as well as the dependence on the understanding of gnuplot commands and syntax.
gnome
I'm just beginning to learn to use gnuplot & can't figure out how to display a cylindrical surface in 3D.
Even a simple one like x2 + y2 = 1
Oh, and how about a vertical plane?
Anybody know how to do this?
Computer science news on Phys.org
try using the splot command.
for example:
gnuplot> splot -x**3 -y
Thanks, dduardo, but while z = x**3 -y is a surface, it's not a vertical surface & certainly not a cylinder.
I know about the splot command -- I just can't think of a gnuplot-valid expression for a vertical plane or cylinder.
Any ideas about that specifically?
Ah...
If anyone's interested, I found that this can be done by using the "set parametric" command & then giving it parametric expressions for the x, y & z coordinates.
17K
  • · Replies 19 ·
  • · Replies 18 ·
