Are My Higher Derivative Answers Correct?
The discussion revolves around higher derivatives, specifically focusing on the first and second derivatives of given functions. The original poster presents two problems: one involving a rational function and the other an implicit differentiation scenario with a constant.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to find the first and second derivatives of a rational function and an implicit function, expressing uncertainty about their correctness. Some participants suggest using the product rule instead of the quotient rule for the first problem and clarify that the constant 'a' should be treated as such in the second problem.
Participants are actively engaging with the original poster's attempts, providing guidance on differentiation techniques and clarifying the treatment of constants in differentiation. There is a mix of interpretations and methods being discussed, particularly regarding the use of implicit differentiation and the handling of constants.
Some participants question the assumptions about the nature of 'a' in the second problem, leading to a discussion about constants versus variables in differentiation. The original poster expresses confusion about when to treat certain symbols as constants based on previous experiences with similar problems.
scorpa
Hello Everyone,
I'm doing some questions on higher derivatives, and they should be easy but I am worried that my answers are not quite right. There just seems to be something 'off' about them. Anyway here are the questions and my answers.
1) Find the first and second derivatives of y= (4x)/squareroot(x+1)
y' =(squareroot(x+1))(4)-(4x)(1/2)((x+1)^-1/2))/(x+1)
y'=(4squareroot(x+1)-(2x(x+1)^-1/2)/(x+1)
Ok, so that was my first derivative and I think it is ok, now for the second:
y''=((x+1)[(2(x+1)^-1/2)-(2(x+1)^-1/2)-(x(x+1)^-3/2)] -4squareroot(x+1)+2x(x+1)^-1/2)/(x+1)^2
I hope that doesn't look to confusing but I have a bad feeling it is.
2) Find the first and second derivatives of x^4+y^4=a^4
My biggest issue with this one is that I'm unsure of how to deal with the a, I just treated it like the x, and used implicit differentiation:
x^4 + y^4 = a^4
4x^3 + 4y^3 y' = 4a^3
y' =(4a^3 - 4x^3)/4y^3
y' = (a^3 -x^2)/y^3
y'' = y^3(3a^2-3x^2)-3y^2(a^3-x^3)/(y^6)
y'' = 3y^2 (ya^2-yx^2-a^3+x^3)/y^6
y'' = (3(ya^2-yx^2-a^3+x^3))/y^4
Well there it is, hope what I've shown makes sense, I know it is hard to read on a computer. Thanks for any help guys, I really appreciate your time and effort.
in the second problem 1 is a constant ant dy/dx of a constant is zero
Sometimes, differentiating quotients, it is simpler to use a negative exponent and use the product rule rather than the quotient rule.
For (1) write the function as y= 4x(x+1)1/2.
Then y'= 4(x+1)1/2+ (4x)(1/2)(x+1)-1/2.
= 4(x+1)1/2+ 2x(x+1)-1/2
Now y"= 4(1/2)(x+1)-1/2+ 2(x+1)-1/2-(2x)(1/2)(x+1)-3/2
= 4(x+1)-1/2- x(x+1)-3/2.
Since the original problem was written as a fraction, you might want to write that as (3x+ 4)/(x+1)3/2 or
[tex]\frac{3x+4}{\sqrt{(x+1)^3}}[/tex].
As mathmike pointed out, the "a^4" is a constant. Its derivative is 0. You have x4+ y4= a4 so 4x3+ 4y3y'= 0 or simply x3+ y3y'= 0. Now it's better not to solve for y' but just use implicit differentiation again:
3x2+ 3y2y'+ y3y"= 0
Now [tex]y"= -\frac{3x^2+ 3y^2y'}{y^3}[/tex].
That still has y' in it but that's okay.
= 4(x+1)1/2+ 2x(x+1)-1/2...
Uhmm,... there's a slight error in it.
It should read: y= 4x(x+1)-1/2, not y= 4x(x+1)1/2 :smile:
So:
y'= 4(x+1)-1/2 - (4x)(1/2)(x+1)-3/2.
= 4(x+1)-1/2 - 2x(x+1)-3/2 = (4x + 4 - 2x)(x+1)-3/2 = (2x + 4)(x+1)-3/2.
y'' = 2(x+1)-3/2 - 3 / 2 (2x + 4)(x+1)-5/2
= (2x + 2 - 3x - 6)(x+1)-5/2 = (-x - 4)(x+1)-5/2
[tex]= -\frac{x + 4}{\sqrt{(x + 1) ^ 5}}[/tex].
Viet Dao,
Hmmm ok, I never realized that a should be taken as a constant. Now that I know you have to take it as a constant, could someone please explain why to me? How do you know a is a constant instead of just another variable, I had a question awhile ago where we had to take the derivatives of d's and b's and a's all together in a question and I'm not sure how to tell when you take it as a constant or not. As for the other questions thanks again for the help, I will go and try it using the product rule as you suggested and see if I can get it to work out that way. Thanks a lot.
the derivative of x^n = nx^(n-1)
and if it is ax^n it would be anx^(n-1)
and d/dx[a]=0
so if you take the der of something that is multiplied by a constant then the der is still multiplied by the constant.
but if it has no variable then it will go to zero
OK thanks again. I understand that the derivative of a constant is zero, but I guess what I am trying to ask is how to you know for sure that a is a constant? I am asking this because I have had a question before where you had to differentiate a's and b's and there were no x's in front of them, you did it as though a was not a constant. Maybe I am just being stupid here...haha.
The problem asked you to find dy/dx. The only way you can do that is if y is a function of the single variable x: a can't be a variable.
You probably haven't covered partial derivatives yet, but even if you were given that y was a function of the two variables x and a, the partial derivative [tex]\frac{\partial y}{\partial x}[/tex] would be done by treating a as if it were a constant so you would get the same answer.
Oh, ok I think I understand now, thank you!
  • · Replies 25 ·
