Thread Closed
Ballistic pendulum..
Share Thread Thread Tools
Nov1-05, 03:48 PM   #1
How do I go about solving this problem? No diagram is given, so it's a little hard-to-picture in my head, so I drew a basic diagram but it hasn't really helped.
I use a ballistic pendulum. Large block of wood has a mass M2 = 3.000 kg, and the bullet has a mass of m1 = 25 g. In this problem the bullet completely penetrates the wood and emerges with a speed of vf = 40.0 m/s. The wood, as part of a pendulum, swings up to a maximum height of h = 4.0 cm.
Determine the speed of the block of wood after the bullet has passed through it, and the initial speed of the bullet.
Much thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Nov1-05, 04:01 PM   #2
Recognitions:
Homework Helper Homework Help
Conservation of mechanical energy (PE and KE) tells you how fast the block was going after the collision.
Conservation of momnetum tells you how fast the bullet was going before the collision.
Nov1-05, 04:07 PM   #3
So I should be using ½mv² and mgh? The mass of what though? The bullet or the block of wood? Or both? Also, what does the question mean when it says: "with a speed of vf = 40.0 m/s" - what is vf?
Nov1-05, 04:15 PM   #4
OK, I worked out the Kinetic Energy of the bullet, having passed through the block, using ½mv², and I got a value of 20J, having converted everything into m and kg. Then I calculated the Potential Energy of the block, using mgh, and I got 1.1172J, but I don't see how this helps me...I thought I need to use theta and sine/cosine to answer this? Or is it all to do with energy? Thanks
Nov1-05, 04:44 PM   #5
Recognitions:
The ballistic pendulum stuff generally works this way:
There is a perfectly inelastic collision between the bullet and the target, and then the swing up has conserved energy.
Nov1-05, 05:52 PM   #6
Recognitions:
Quote by lando45
OK, you got PE. This is PE at the top. What kind of energy was it at the bottom?
Nov2-05, 12:59 AM   #7
Quote by Chi Meson
Kinetic energy?
Nov2-05, 05:31 AM   #8
Recognitions:
yes. what is the formula for KE. Can you fid the speed of the block at the bottom (right after the collision with the bullet)?
Thread Closed
Thread Tools
Similar Threads for: Ballistic pendulum..
Thread Forum Replies
Ballistic Pendulum Introductory Physics Homework 11
ballistic pendulum Introductory Physics Homework 7
Ballistic Pendulum! Introductory Physics Homework 2
ballistic pendulum Advanced Physics Homework 1
Ballistic Pendulum Introductory Physics Homework 9
