Is the Work Done by Gravity Calculated Incorrectly?
The discussion revolves around calculating the work done by gravity on a block sliding down an incline while being pushed by an applied force. The problem involves understanding the forces acting on the block and the work-energy principle in the context of gravitational and applied forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculations of work done by both the applied force and gravity, questioning the relationship between these values. There are inquiries about the correct interpretation of distance in the work formula and the components of gravitational force acting on the block.
The discussion is active, with participants sharing their calculations and questioning the assumptions made regarding the work done by gravity. Some have provided insights into the components of gravitational force and how they relate to the displacement vector, while others are seeking clarification on the correctness of their approaches.
Participants are working under the constraints of a homework problem that requires them to analyze forces and work done in a specific physical setup involving an incline. There is an emphasis on understanding the components of forces and their contributions to work without reaching a definitive conclusion.
suspenc3
Work Question..Anyone?!
Im doing a problem and I found the work done by an applied force to be 401J.
I then found the work done by gravity to be -330.8J
Does this mean that i made an error..Arent (Wg + Wa) suppose to = 0
There is a mass sitting on an incline and a force is applied so that it slides down at a constant speed.
I found F=267N
W=Fd...
W=401J
Wg=mgdcos(a)
Wg=-330N
Is d the total distance travelled..Or the y component of the distance travelled
Please post the problem statement!
Sure here is it
A 45kg block of ice slides down a frictionless incline of 1.5m long and 0.9m. A worker pushes up against the ice parallel to the incline, so that the block slides down at a constant speed.
a)find the magnitude of the workers force
b)how much work is done on the block by the workers force
c)" " the gravitational force on the block
d)the normal force on the block from the surface on the incline
e)the net force on the block
Ok so show me your work, and/or where did you get stuck?
drew the fbd's and came up with:
-mgsin(theta) - F = -ma (a=0)
-mgsin(theta) = F
plug in numbers
F = 267.5N
Wf = Fd
Wf = 267.5N(1.5m)
Wf = 401J
Wg = mgdcos(phi)
Wg = 45kg(9.8m/s)(1.5m)(cos120)
Wg = -330.8J
This can't be correct because Wg +Wf = 0?
i suppose the 1.5 and 0.9 are sides of the triangle right?
1.5 = hypotenuse
0.9 = height
Ok i see the problem the mgcos(phi) component of gravity does not do work!, because it is perpendicular to the displacement vector, so the dot product will be 0!
soo...how do i find the work done by gravity
Gravity does work!, but only one component of gravity!, the one that is parallel to the displacement vector.
but gravity is not perpendicular to the displacement vector..
mgdcos(phi) makes it parallel to the displacement vector doesn't it?
You have the gravity vector pointing down, and if you system of coordinates is directed at the angle the incline has, so the x-axis is parallel to the hypotenuse, and the y-axis is perpendicular to the hypotenuse, then you can decompose gravity in two components, one along the y-axis (mgcos(angle)), and one along the x-axis (mgsin(angle)), the displacement vector goes along the x axis.
so to find the work done by gravity all i have to do is mgcos(30)
is everything before this correct by the way?
If so wouldn't Wg equal (-Wf)
No, that's wrong i already explained why.
Yes Wg IS equal -Wf.
ok..but if i just mark this down i won't get any credit for it
How could I prove that -Wf = Wg using my FBD's?
I already say why :rolleyes:
Try reading my #14 and #10 replies.
The forces are in equilibrium and gravity's working component is the equilibriant of the worker's force. Both of their magnitudes are given by mgsin(arctan(0.9/1.5)).
  • · Replies 58 ·
