How Is Equilibrium Temperature Calculated in Isolated Thermodynamic Systems?
  • Thread starter Thread starter berthanas
    Thermodynamics
The discussion focuses on calculating the equilibrium temperature in isolated thermodynamic systems, specifically involving a 10 kg copper block at 30°C and 0.2 kg of saturated water vapor at 130°C. The final equilibrium temperature can be determined using the principle of conservation of energy. Additionally, the discussion addresses a cylinder containing ammonia at 1 MPa and 60°C, where work is done on the system, requiring calculations for the final temperature and heat transfer during the process.
  • Understanding of thermodynamic principles, specifically the conservation of energy.
  • Familiarity with phase changes and properties of saturated water vapor.
  • Knowledge of the ideal gas law and its application to ammonia.
  • Basic skills in performing thermodynamic calculations involving work and heat transfer.
  • Study the conservation of energy in thermodynamic systems.
  • Learn about the properties of saturated water vapor and its phase transitions.
  • Research the ideal gas law and its application to real gases like ammonia.
  • Explore methods for calculating heat transfer in thermodynamic processes.
Mechanical engineering students, thermodynamics learners, and professionals involved in energy systems and heat transfer analysis will benefit from this discussion.
berthanas
hi I'm a mechanical engineering student. I've 2 questions as homework for tomorrow but since I've missed couple of classes i couldn't solve them. i'd appreciate if you may help me with these:
1.) An isolated system consists of a 10 kg copper block, initially at 30 0C , and 0.2 kg of saturated water vapor, initially at 130 0C.Assuming no volume change, determine the final equilibrium temperature of the isolated system.
2.) A cylinder fitted with a piston restrained by a linear spring has a cross-sectional area of 0.05 m2.The cylinder contains ammonia at 1 MPa ,60 0C, and a volume of 20L.The spring constant is 150 kN/m.Heat is rejected from the system, and the piston moves until 6,25 kJ of work has been done on the ammonia.
a.) Find the final temperature of the ammonia.
b.) Calculate the heat transfer for the process.
thanx already...
Well the policy here is to show your work, why don't you read the chapter of your book on this, and then post your attempt?
  • · Replies 16 ·
32K
  • · Replies 135 ·
10K
12K
