What Are the Best Blade Angles and Generators for Domestic Fans?
  • Thread starter Thread starter anne and ol
The discussion centers around the design and efficiency of domestic electrical fans, specifically focusing on optimal blade angles, shapes, generator suitability, and operational principles. The scope includes engineering considerations and practical applications related to fan performance.
  • One participant suggests an optimum blade angle of 30 - 35 degrees tangent to the blade contact point, citing its importance for ideal ink distribution, although this may not directly apply to domestic fans.
  • Another participant emphasizes the significance of blade material selection, discussing advanced steel properties and their implications for performance, but this is more relevant to inkjet applications than room fans.
  • Participants express confusion regarding the relevance of the initial responses, indicating a need for information specifically about room cooling fans rather than inkjet technology.
  • A later reply indicates a lack of specific knowledge about room fans, suggesting a need for further contemplation on the topic.
  • One participant questions the appropriateness of the thread's placement in the forum, suggesting it may be better suited for the Engineering or Technology sections.
Participants do not appear to agree on the relevance of the information provided, as some responses pertain to inkjet technology rather than domestic fans. The discussion remains unresolved regarding the specific questions posed about room fans.
There is a lack of clarity on the assumptions regarding the type of fans being discussed, leading to confusion and irrelevant contributions. The discussion also highlights the need for precise definitions and context when addressing engineering queries.
Individuals interested in the design and efficiency of domestic electrical fans, as well as those exploring engineering principles related to fan technology.
anne and ol
Domestic fans...please help!
Hey everyone.
WE are currently undertaking an engineering project and need some simple, yet seemingly unobtainable, answers to some questions. The questions are regarding domestic electrical fans. If you have the answers to these questions, or any useful hints about wind power, please reply to this post or email me.
1. WHAT IS THE OPTIMUM BLADE ANGLE, SHAPE?
2. HOW EFFICIENT ARE THEY
3. WHAT KIND OF GENERATOR WOULD BE MOST SUITABLE AND MOST EFFICIENT
4. HOW DO THEY ACTUALLY WORK?
If you could answer these questions or help us in any way please please get in touch as we have hit a bit of a wall and need a kick in the right direction.
many thanks, anne and ol. :smile:
blade angle
The optimum blade angle is 30 - 35 degrees tangent to the blade contact point
This window facilitates ideal ink distribution in conjunction with slow, consistent doctor blade wear.
BLADE SELECTION
Choosing the correct steel is of the utmost importance! XcaliburTM highly refined doctoring steels are considerably more advanced than those produced by conventional methods. A proprietary metallurgical method of steel purification produces noteworthy improvements in physical properties, in particular fatigue properties, impact strength and ductility . The micro granular structure of XcaliburTM steel degrades in a very even and consistent fashion along the entire width of your engraved cylinder; it wears like sand not gravel! The end result is the most consistent ink film thickness being delivered to your substrate with minimum trauma caused to the surface of your engraved cylinder. Also, the micro granular particles are easily transported and collected in your ink stream. A filter/magnet system on your return line to the fountain will remove contaminant’s and metal particles from your ink stream. Refined magnetic collection systems are currently being introduced to improve the collection process. Regardless of your method, filter/collection systems should be monitored and cleaned on a regular basis to avoid plugging.
Stainless steel blades are often used in corrosive applications but due to their lower tensile strength and hardness tend to fracture at the tip introducing large metal fragments into your ink stream. The area of fracture leaves undesirable voids in the doctoring tip. As previously mentioned plastic and synthetic blade materials "utilized for primary doctoring" allow particles to imbed in the doctoring tip which leads to printing defects.
Selecting the ideal doctor blade for your specific application is greatly influenced by your anilox roll specifications, enclosed chamber configuration, machine width and speed, type of ink and its viscosity. Consult your XcaliburTM representative for a detailed analysis.
ANILOX ROLL WEAR
The reason for abrasive wear of the anilox (hardness 1100-1200 Vickers related to doctor blade hardness of 565-580 Vickers) can be micro fractures in the ceramic layer resulting in small ceramic particles coming into the blade contact zone and damaging the anilox cell structure . This can occur in new rollers that are not properly finished or when ceramic chips away from your anilox roll at the outer edges. It is essential that the surface of your roller be free of ceramic burrs. Consult your anilox roll supplier for complete details.
thankyou
Thanks for replying to our problem but we were referring to fans that cool the room not inkjet fans. if u have any information concerning these types of fans please send us info.
thanks again
anne and ol:smile:
himm
ohhh
i have only this information in my mind.
let me think for the room fans.
So what does any of this have to do with philosophy? You might want to try contacting the forum moderator and ask that this be moved to the Engineering or Technology forum.
Thanks.
