Abstract Algebra (Normal Subgroups)
The discussion revolves around problems in abstract algebra, specifically focusing on normal subgroups and properties of homomorphisms. The original poster presents two problems: the first involves proving that the image of a normal subgroup under a surjective homomorphism is also a normal subgroup, while the second concerns the commutativity of elements from two normal subgroups with trivial intersection.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the properties of the image of a normal subgroup under a homomorphism, questioning how to demonstrate that f(K) retains the normal subgroup properties. There are attempts to clarify the subgroup test and the implications of surjectivity. For the second problem, participants explore the relationship between normal subgroups and their intersection, considering examples and properties of specific groups to understand the implications of the intersection being trivial.
Some participants have offered insights into the properties of homomorphisms and the structure of normal subgroups, suggesting that exploring concrete examples may aid understanding. There is an ongoing exploration of the necessary conditions for the problems, with no explicit consensus reached on the solutions.
Participants note the challenges posed by the definitions and properties of normal subgroups, as well as the implications of the intersection condition in the second problem. The discussion reflects a learning environment where assumptions and definitions are critically examined.
mattmns
Hello. We got a review today in abstract algebra, and I am stuck on two problems.
1) Let f: G -> H be a surjective homomorphism of groups. Prove that if K is a normal subgroup of G, then f(K) is a normal subgroup of H. Where f(K)= {f(k): k [tex]\in[/tex]K}
The entire f(K) part is really throwing me off.
We know:
G and H are groups
Also H is a normal subgroup because im_f = H (because f is surjective)
The real problem is I don't quite understand the whole f(K) part. Any ideas about what f(K) is, and any ideas about the problem?
2) If H and K are normal subgroups of a group G satisfying H[tex]\cap[/tex]K = {1}, prove that hk = kh for all h[tex]\in[/tex]H and k[tex]\in[/tex]K.
This one is really throwing me off.
We Know:
H and K are normal subgroups of a group G.
H[tex]\cap[/tex]K = {1} is a normal subgroup of G. (because of a previous problem I had proved).
Also, HK is a subgroup (by a theorem from my book)
For this problem it seems that it would be sufficient to show that G is abelian, but I am not sure how we would do that. Or maybe just use some general properties algebraically to show that hk=kh. I am not sure how we are supposed to use the H[tex]\cap[/tex]K = {1} though.
Any ideas about this one?
Thanks!
subgroup test comes to mind. oh wait never mind you have to prove normal subgroup sorry prolly not that easy then
Yes, but I am not understanding how I would say that 1 is in f(K), or x,y in f(K) => xy in f(K), my real problem is understanding how I would use f(K) to see if the properties of a subgroup apply to f(K). Any ideas about f(K)?
yes I had a problem like this but it was dealing with isomorphisms I think I assumed f(a) and f(b) were in f(k) then I said f(a)f(b) was in f(k) since ab is in k so f(ab) is in f(k) and f(ab)=f(a)f(b), similar argument holds for a inverse
f(k) is non empty because f(e) is in f(k)
since k is a group it has all the properties we need like identity and a,b in k implies ab in k so f(ab) is in f(k)
a in k then a^-1 in k so f(a^-1) is f(k)
f(a^-1) = (f(a))^-1
Hmm, that is an interesting idea, I think I remember my teacher doing something similar, I will try it out, thanks. Any ideas for #2?
for the 1st one you've got to show that the subgroup f(K) is normal in H, that is, [tex]f(K) = f(x)f(K)f(x)^{-1}[/tex] for any f(x) in H if K is normal in G.
unless i made a mistake (or I'm getting better at algebra) it's not very hard. all you've got to use, after all, is properties of homomorphisms to show that the image is a normal subgroup. i think the reason you need a surjective homomorphism is so that you get a group in the image, otherwise you could get the empty set as an image which isn't a normal subgroup.
for the 2nd one i'd try out some examples. the quaternions is a noncommutative group in which every subgroup is normal, so you're idea won't work (showing it's abelian). try playing with a concrete example like the quaternions & see if that helps.
1) Let f: G -> H be a surjective homomorphism of groups. Prove that if K is a normal subgroup of G, then f(K) is a normal subgroup of H. Where f(K)= {f(k): k in K}
Suppose x is in f(K) and h is in H. To show f(K) is normal, you want to show that hxh-1 is in f(K). Well you know that since f is surjective, there is some g in G such that f(g) = h. Since x is in f(K), you know there is some k in K such that f(k) = x. So you can pick g and k such that:
hxh-1 = ... (figure the rest out)
2) If H and K are normal subgroups of a group G satisfying H[itex]\cap[/itex]K = {1}, prove that hk = kh for all h in H and k in K.
Do you know that if H is normal, then for every g in G, gH = Hg? In other words, for every g in G and for every h in H, there is some h' in H (possibly the same as h) such that gh = h'g. This holds for every g in G, including every g in K. Can you go from here?
yeah i think i made a mistake. i should think harder
Thanks everyone, I got them both :smile:
