Linear Momemtum Need dire assistance
The discussion revolves around a problem related to linear momentum, specifically calculating the average braking force of a car brought to a stop over a specified time period. The original poster expresses difficulty in understanding the problem and seeks assistance.
  • Participants discuss Newton's Second Law and its application to the problem, noting the relationship between force, mass, and acceleration. Some mention the need for additional variables to fully address the question. Others highlight the connection between force and the change in momentum over time.
The discussion is ongoing, with participants offering hints and exploring different interpretations of the problem. There is a focus on the application of fundamental physics principles, but no consensus has been reached regarding the specific approach to take.
Some participants note that certain variables are missing, which may affect the ability to solve the problem completely. The original poster's absence during the initial explanation may also contribute to their confusion.
Vivek
Ladies and Gentlemen
This is from my class work and i was not there when the teacher did this.I want to understand this.Please assist
A car with a linear momentum of 3.0 x 10 raised to 4 KG x M/S is brought to a stop in 5.0 sec.What is the manitude of the average braking force?
I really don't get this one.Any help is more than appreciated.:smile:
Hint: Newton's Second Law can be thought of in this way:
[tex]\Sigma F = \frac{d}{dt} (mv)[/tex]
The second law is that the acceleration of an object is dependent on two factors - the net force acting upon the object and the mass of the object...
But in relation to the question there are a few variables missing..:confused:
integral of force-time graph is change in momentum
Most simply, force equals mass times acceleration. Although you are given the initial momentum, rather than the initial speed, since momentum equal mass times speed, and mass stays contant in this problem, just divide the "change in momentum" (from 3.0 x 104 to 0) by the time required.
Look at it like this...Starting with
[tex]F = m a[/tex] where [tex]a = \frac{d}{dt} v[/tex]
[tex]F = m \frac{d}{dt} v[/tex] since mass is constant, we can pull it inside the derivative
[tex]F = \frac{d}{dt} (mv)[/tex] or [tex]F = \frac{d}{dt} P[/tex] where P = mv is the linear momentum.
So if the force is equal to the time rate of change of the momentum, how does that fit into your problem?
10K
19K
