(1+x)^2/x^6 doesn't simplify?
  • Thread starter Thread starter Pengwuino
    Simplify
The discussion revolves around the simplification of the expression \(2\sqrt{\frac{(1 + 2t^4)^2}{t^6}}\) and the implications of removing square roots in algebraic expressions. Participants are exploring the conditions under which simplifications can be made, particularly focusing on the role of square roots and absolute values in the process.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster questions whether the square root allows for simplification without it, and why the square root enables certain reductions. Other participants discuss the implications of absolute values in simplifications and the conditions under which terms can be canceled.
Participants are actively engaging with the problem, providing insights into the mathematical properties of square roots and simplifications. There is a recognition of the importance of maintaining positivity in quantities during simplification, and some guidance has been offered regarding the manipulation of the expression.
There is an ongoing discussion about the assumptions regarding the positivity of variables and the implications of removing square roots in algebraic expressions. The original poster expresses confusion about previously held beliefs regarding simplification rules.
Pengwuino
Ok I got an equation here...
[tex]2\sqrt {\frac{{(1 + 2t^4 )^2 }}{{t^6 }}}[/tex]
is the equation (sorry for misleading title but its the same concept).
Now I was always under the assumption that the top square could be removed as long as you reduce the bottom to [tex]t^3[/tex] since [tex]t^3[/tex] squared is [tex]t^6[/tex] and that you can cancel out squares like that. I guess I'm wrong? I'm running some examples in my mind and I'm kinda realizing you can't do it... but i feel like I've always thought it was true for soem reason.
I also did a simplification through mathematica and found out that the square root actually allows you to remove the [tex]^3[/tex] to get to the [tex]t^3[/tex].
The first question I'm asking is: without that square root... would I be able to simplify?
The 2nd question is exactly why I am able to use that square root to simplify. Sorry if its confusing...
Well you can get rid off the square root, since
[tex] \sqrt {\frac{{a^2 }}<br /> {{b^2 }}} = \sqrt {\left( {\frac{a}<br /> {b}} \right)^2 } = \left| {\frac{a}<br /> {b}} \right|[/tex]
Yah I was under the impression that even without that square root, it could turn into a/b
Just remember that the quantity has to remain positive. So the simplification of the original equation is:
[tex] |{1/t^3 + 2t}|[/tex]
If you want to see the reduction broken down then this is what you should do.
[tex]2\sqrt{\frac{(1+t^4)^2}{t^6}} =2\left(\frac{(1+t^4)^{2\frac{1}{2}}}{t^6}\right)^{\frac{1}{2}}[/tex]
[tex]=2\frac{(1+t^4)^{2\frac{1}{2}}}{t^{6\frac{1}{2}}}=2\frac{1+t^4}{t^3}[/tex]
[tex]=2t^{-3}+2t^{-3+4}=|2(t^{-3}+t)|[/tex]
which almost yields the same result as knavish. I think he is missing a factor of 2 somewhere in there as
p.s. sorry I didn't break it down with the absolute value signs, but those were already explained pretty well... and for some reason I like to add them afterwards. bad habit i guess
  • · Replies 24 ·
