Looking for the granularity of spacetime
  • Context: Graduate
  • Thread starter Thread starter wolram
    Spacetime
The discussion revolves around the concept of spacetime granularity and the potential observation of Cherenkov radiation in relation to hypothetical tachyons. Participants explore the implications of tachyons traveling faster than light, the conditions necessary for Cherenkov radiation, and the nature of spacetime as a medium.
  • Some participants suggest that if tachyons exist, they should produce Cherenkov radiation, but question whether this can occur in a vacuum.
  • Others argue that the absence of observable blue radiation from the vacuum contradicts the existence of tachyons.
  • A participant raises the point that Cherenkov radiation requires a medium, which a vacuum does not provide, leading to questions about how it could manifest in such conditions.
  • There are references to external sources claiming that Cherenkov radiation could be observed in a vacuum with tachyons, but skepticism is expressed regarding the credibility of these sources.
  • Some participants propose that if spacetime has a granular structure, it might act as a medium, allowing for the possibility of observing Cherenkov radiation from superluminal particles.
  • Questions arise about whether these "Planckian cells" could possess charge, similar to how water molecules are polarized by charged particles.
  • A later reply discusses speculative papers suggesting that Cherenkov radiation could be detectable in the vacuum, adding complexity to the discussion.
  • Concerns are raised about the fundamental nature of traveling faster than light and the implications of special relativity on this concept.
Participants express a range of views, with no consensus reached on the existence of tachyons or the conditions necessary for observing Cherenkov radiation in a vacuum. The discussion remains unresolved with competing hypotheses and interpretations.
Limitations include the speculative nature of tachyons and their interaction with spacetime, as well as the dependence on definitions of medium and charge in the context of vacuum and granularity.
wolram
Dearly Missed
on the subject of looking for the granularity of spacetime,
cherenkov radiation is given of if a particle exceeds c
when traveling through a medium, i know that water is used
for the medium on Earth as it does not require the initial
>c particle, but tachyons if they exist travel many times
c so cherenkov radiation should be observable in spacetime,
or am i wrong as usual?
If tachyons would exist you would observe a blue radiation coming from the vacuum all the time. The no existence of this light practically is the death sentence for tachyons
or of space time, heads or tails, or i could be totally
wrong, maybe someone will put us on the right track?
Perhaps proponents of tachyons would say that Cherenkov radiation requires a medium for the particle to collide with? This would seem a reasonable response, as a vacuum does not collide with anything. At least, not in the classical sense of "collision" which gives rise to CR.
LURCH has raised an interesting point, and is what could cause the Cerenkov radiation in a vacuum?. In a medium like water, for example, when a particle travels faster than light in that medium, the molecules of water are polarized in the direction of movement of the particle, and after a while return to their normal state, emitting a pulse of blue light. But what can be polarized in a vacuum?
However there are a bunch of pages in Internet that claims that Cerenkov radiation should be observed in a vacuum when tachyons are present
http://www.geocities.com/ashokktiwari/tachyons.html
http://www.physics.gmu.edu/~e-physics/bob/h.htm
Should I conclude that these are crank pages?
Oh, well, I've reading the second of my links, and say that charged tachyons should have been observed provoking Cerenkov radiation, but not necessarily not charged tachyons
But still I don't understand hoew a charged tachyon can provoke Cerenkov radiation in a vacuum
i think this has more to do with the idea that spacetime is
grainy and is made up of Planckian cells, a bit like
uniform bubbles, QLT suggests that spacetime has structure
and is not just the vacuum, so if spacetime has structure
it can be considered to be a medium.
i think this is why it is considered possible to observe
cherenkov radiation if anything is traveling >C in
"spacetime".
But the molecules of water are polarized because they have charge and are affected by the passing of a charged particle. Are you suggesting that these "planckian cells" have charge too?
no i am suggesting nothing, i am just trying to understand
or explore the possibilities, but gravity has the potential
to do work, so it could be given an energy value, why not
in the form of charge?
http://arxiv.org/PS_cache/astro-ph/pdf/9610/9610089.pdf
this paper is speculative but in section 2 dynamics
and cosmology it suggests that cherenkov radiation
is detectable in the vacuum.
http://math.ucr.edu/home/baez/physics/Relativity/GR/grav_radiation.html
However, there is good evidence that Cgw is in fact at least almost Cem. We observe high energy cosmic rays in the 1020 to 1021 eV region. Such particles are traveling at up to (1-10-18)*Cem. If Cgw < Cem, then particles with Cgw < v < Cem will radiate Cherenkov gravitational radiation into the vacuum, and decelerate from the back reaction. So evidence of these very fast cosmic rays is good evidence that Cgw >= (1-10-18)*Cem, very close indeed to Cem. Bottom line: in a purely Einsteinian universe, Cgw = Cem. However, a class of models not yet ruled out experimentally does make other predictions.
it seems that others have already thought about this
and i though it was origonal:frown:
Wait, I could be missing something, but how can anything travel faster than light?
http://en.wikipedia.org/wiki/Speed_of_light
It is important to realize that the speed of light is not a "speed limit" in the conventional sense. As a consequence of the theory of special relativity, all observers will measure the speed of light as being the same. An observer chasing a beam of light well measure it moving away from him at the same speed as a stationary observer. This leads to some unusual consequences for velocities.
its all very unintuitive, but you will find lots on the
web.
  • · Replies 27 ·
  • · Replies 23 ·
  • · Replies 36 ·
  • · Replies 43 ·
