Thread Closed
A few questions about schematic
Share Thread Thread Tools
Nov6-05, 10:41 PM   #18
Mentor
Sure, whatever. Real world verusus the lab.
Nov6-05, 11:49 PM   #19
Quote by berkeman
Alright, cool. Thx for all the help. I will be sure to post results and pics once I finish it here within a month. That is, if I don't have anymore questions during that time
Nov7-05, 09:07 AM   #20
Well I'm back again. Since I have to order parts online, I have to wait a few days to work on the reciever/transmitter circuits. I figure I might as well make the stepper motor circuit while I have this free time. Could anyone supply me with a circuit in which I could do this?
The stepper motor is supposed to sweep 180 deg, back and forth. The first my professor gave me was the L298 Dual Full-Bridge Driver.
http://tinyurl.com/e42un
The other is the L297 Stepper Motor Controller.
http://tinyurl.com/bzokx
Edit: Here is the data sheet for the stepper motor
http://www.jameco.com/wcsstore/Jamec...dDS/213321.pdf
Nov7-05, 12:59 PM   #21
Mentor
You're going to need at least a CPLD or a microcontroller to drive the stepper motor circuit & process the sonar returns. What is your strategy for that part of the circuit?
Nov7-05, 01:09 PM   #22
Quote by berkeman
I plan on separating the two circuits. The stepper motor circuit will turn back and forth 180 degrees. Thats all it will do. I will have the transducers hooked up with long wires and mount them to something fairly sturdy to put on the motor to turn.
Nov8-05, 06:01 PM   #23
Could anyone supply me with a schematic for the stepper motor with the chips that I was given?
Nov8-05, 06:21 PM   #24
Mentor
Quote by maverick99
The link you supplied for the L297 has an Application Note link underneath it. It looks to be a pretty complete tutorial. Just click through your link and look for the Application Note link:
Nov8-05, 06:55 PM   #25
Quote by berkeman
In that pdf files, what is the MCU?
Nov8-05, 07:02 PM   #26
Mentor
Any general purpose microcontroller could be used. That's why I asked earlier in the thread what CPLD or uC you planned on using. You will need at least some logic to provide those control signals to the stepper driver. It would be a good idea to also have limit switches at the ends of your 180 degree travel, to help your uC do some sort of initialization routine after power up or other reset.
You can start off playing with the motor by just using switches to provide the input signals....
Nov8-05, 07:23 PM   #27
When testing the motor, do i need any current limiting components?
Nov9-05, 01:16 PM   #28
On the schematic that was given, what is the purpose of the 8 diodes? Would rectifier diodes work for the schematic?
Nov9-05, 01:38 PM   #29
Mentor
Quote by maverick99
Look at the currents in figures 15 and 17 for your answer. Any diodes should work as long as they have adequate current and power ratings.
Nov9-05, 02:20 PM   #30
Alright cool, sounds good. I tested out the motor and got it working right with just a dip switch. I will need to program a chip to count the way i need it to, too. My question is, do i even need the l297 and l298 in the circuit? Couldn't I just simulate the dip switch counting with the programmable chip and have that going to the motor? If not, then what are the l297 and 298 doing in the circuit?
Nov9-05, 03:04 PM   #31
Mentor
You could probably drive the correct waveforms from your uC into the power transistors that drive the motors -- might even get you extra credit in the project. You need to make the correct waveforms for the stepping and holding currents, but yeah, the uC could do that if you program it right.
Nov16-05, 02:12 AM   #32
Recognitions:
Homework Helper Homework Help
Quote by maverick99
Why would I have to include a power source and voltage regulators on the final project assembly? Wouldn't it work fine if I just used the 5 Volt line from my power supply and used the other output for 9V?
If you did want to make a real world design as berkeman suggested, using a voltage regulator to step down a 9v supply to 5v is not hard. On the bench, you could determine how much current is drawn by your design and then decide if a 9v battery could work for the high supply..
Nov16-05, 02:23 AM   #33
Recognitions:
Quote by maverick99
How will you mount the transducers so they will be turned by the stepper motor? Will transducers be on the same board as the rest of your circuit? I am trying to get a 3-dimensional idea of your final setup. Are you going to go with a circuit like the minibot one you posted at the end of #11 of this thread?
Nov16-05, 07:56 PM   #34
Recognitions:
How about the range of your Ultrasonic Design. The spec for the project is 25feet. Only one of the circuits referenced on this thread are rated for that distance.
SRF04 Ultra Sonic Ranger
max range is 3m (x 3.28 ft/meter) = 9.84 ft
Ultra Sonic Rangemeter
max range 3.6m (x 3.28 ft/meter) = 11.8ft
Sonar Ranging System for Minibot
max range 5-6ft
Ultra-Sonic Ranging Design
max range 10.7m (x 3.28) = 35 ft
If you did go with one of the other designs, is there a way to improve gain of the circuit?
Perhaps use more sensitive transducers?? (see below)
Scientific Technologies, Inc.
Sensors with range 25ft
NEMA6 Acu-trac
Sensors 8m (25ft)
Thread Closed
Thread Tools
Similar Threads for: A few questions about schematic
Thread Forum Replies
Reactor schematic review Nuclear Engineering 1
Circuit Schematic General Physics 3
PSpice Schematic help Electrical Engineering 3
Schematic Question? Electrical Engineering 2
Schematic Diagrams Introductory Physics Homework 1
