Balancing Redox Reactions in Basic Solutions
  • Thread starter Thread starter RoKe
    Redox
The discussion focuses on balancing the redox reaction of hydrazine formation from ammonia and chloramine in basic solution, represented by the equation NH3 + NH2Cl + OH- -> N2H4 + Cl- + H2O. The correct coefficients for NH3, OH-, and N2H4 are all 1. The method employed, which involves balancing hydrogen with OH- instead of H+, is confirmed as valid for reactions under alkaline conditions. The conversation emphasizes that different equations may require various balancing techniques, but the approach used in this case is effective.
  • Understanding of redox reactions
  • Familiarity with balancing chemical equations
  • Knowledge of basic and alkaline conditions in chemistry
  • Proficiency in using hydroxide ions (OH-) in reactions
  • Research the half-reaction method for balancing redox reactions
  • Study the role of hydroxide ions in alkaline chemical reactions
  • Explore different techniques for balancing complex redox equations
  • Learn about the formation and properties of hydrazine (N2H4)
Chemistry students, educators, and professionals involved in chemical reaction analysis and redox balancing, particularly in basic solutions.
RoKe
Formation of Hydrazine from Ammonia and Chloramine in basic solution.
NH3 + NH2Cl -> N2H4 + Cl-
What are the coefficients of NH3, OH-, and N2H4 in the balanced equation?
I basically just balanced the hydrogens with an H+, then those with OH-, and got:
NH3 + NH2Cl + OH- ->N2H4 + Cl- + H2O
This is the right answer according to my answer sheet (1, 1 and 1), I was just wondering if this is the correct method. I'm not sure how I would use a half-reaction method here and at my university it's recommended we do not use the oxidation number method. Any explanations on how to approach these problems would be appreciated.
What you've done works just fine. When the question states that the reaction is happening under basic (or alkaline) conditions, you want the equation to involve OH- rather than H+, as you finally have.
The reason what you did worked is because H was the only unbalanced species in the given equation; all other elements were balanced.
Different equations are best solved using different tools (by simply matching numbers of atoms, or using the oxidation number method, or using the half reaction method). In this case, I would have done it the same way you did.
11K
