Inconsistency in special relativity?
The discussion revolves around a perceived inconsistency in special relativity, specifically regarding the timing of a light signal traveling along a moving rod. The original poster presents a scenario involving a rod moving at 0.76c and questions the relationship between the time taken for light to travel from one end of the rod to the other in different reference frames.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the effects of time dilation and the relativity of simultaneity on the timing of events. The original poster questions why the calculated times differ between frames. Others suggest incorporating time dilation and using Lorentz transformations to analyze the situation.
Some participants have provided guidance on the use of Lorentz transformations and highlighted the importance of considering both time dilation and simultaneity. The discussion is ongoing, with participants actively engaging in clarifying concepts and exploring different interpretations of the problem.
There are indications of confusion regarding the application of special relativity principles, particularly in relating the times calculated in different frames. The original poster expresses frustration over the perceived inconsistency, and there are references to external resources that may not be fully resolved within the discussion.
sarahisme
inconsistency in special relativity?
Hey i was just thinking about some of the stuff we have done in SR, and i thought of this situation, and i come up with an inconsistency.
the situation is, you have a rod moving at 0.76c relative to you (the observer). its moving to the right.
if the rest length of the ruler ( call it L') is 400m.
and then if a light signal is sent from one end of the rod to the other
if t' is the time it takes for the light signal to go from one one end of the rod to the other in the frame at which the rod is at rest. then
[tex]t' = \frac{L'}{c}[/tex]
= 1.333 x 10^{-6} s
and if t is the time it takes for the light signal to go from one end to the other in the rest frame of the observer.
since the observer see the length of the rod to be [tex]\frac{L'}{\gamma}[/tex]
then the time it takes for the light signal to reach the other end according to the observer is:
[tex]t = \frac{\frac{L'}{\gamma}}{c} + \frac{vt}{c}[/tex]
= 3.611 x 10^{-6} s s
shouldnt these times be the same? or am i going crazy?
Thanks
-Sarah
I believe you did not incorporate time dilation... i THINK
could you show me what you would get for the each time?
this thing is driving me nuts!
This really isn't my field of expertise (my phd is in sleeping and not doing work)... someone else should be along shortly to take your call. Please stay on the line. *elevator music plays*
ok well i am pretty sure that:
[tex]t = \frac{L'}{\gamma (c - v)}[/tex]
and
but then how are t and t' related?!?
i thought it was by:
[tex]t' = \frac{t}{\gamma}[/tex]
but that doesn't work?
whats going on here?!? :(
The two events (departure of the light from one end of the ruler, and arrival of the light at the other end of the ruler) are at different locations in the ruler's frame of reference. Therefore, in order to find the time between them according to a moving observer, you have to take into account two effects:
1. Time dilation
2. Relativity of simultaneity: if two events at different locations are simultaneous in the ruler's frame, they are not simultaneous in a relatively moving observer's frame. This also affects the time between events that are not simultaneous in the ruler's frame.
To include both effects properly, it's best to use the full Lorentz transformation equations, not the simple time-dilation equation. In your case, with the ruler frame being the "primed" frame and the observer's frame being the "unprimed" one, and [itex]v[/itex] being the velocity of the primed frame in the unprimed one, the equations are:
[tex]x = \gamma (x^\prime + vt^\prime)[/tex]
[tex]t = \gamma (t^\prime + vx^\prime / c^2)[/tex]
where the two frames are such that [itex]x = x^\prime = 0[/itex] at [itex]t = t^\prime = 0[/itex].
For your example, let the light be emitted at the left end of the ruler at [itex]t_1 = t_1^\prime = 0[/itex] and [itex]x_1 = x_1^\prime = 0[/itex] (in the ruler's reference frame); and let the light be received at the right end at [itex]x_2^\prime = 400 m[/itex] and [itex]t_2^\prime = 1333 ns[/itex]. I'll leave it to you to calculate [itex]x_2[/itex] and [itex]t_2[/itex].
1. Time dilation
ok yep that makes sense.
i tryed to apply that approach to question (b) of this question:
http://img379.imageshack.us/img379/948/picture910js.th.png
but it doesn't seem to work! :( would you be able to show me how you would do this part of the question using lorentz transformations?
What, precisely, doesn't seem to work? Show us what you did and I or someone else can probably point out the mistake.
don't worry about it, i think i got it! :)
Thanks for all your help though! :D
  • · Replies 38 ·
  • · Replies 36 ·
  • · Replies 67 ·
