Help with a torque-rotational-inertia-force question please
  • Thread starter Thread starter Windwaker2004
The discussion centers on calculating the force exerted by a fish on a cylindrical fishing reel with a moment of inertia of I=6.22×10-4 kg·m2 and a radius of 4.44 cm. The reel experiences a restraining torque of 1.34 N·m while spinning with an angular acceleration of 66.5 rad/s2. The correct approach involves using the equation T = Iα to determine the total torque required for the angular acceleration, and then calculating the force exerted by the fish by accounting for the resisting torque. The final calculations confirmed the correct answer, simplifying the initial confusion regarding the use of inertia.
  • Understanding of angular motion and torque
  • Familiarity with the moment of inertia concept
  • Knowledge of Newton's second law for rotation
  • Ability to manipulate equations involving torque and angular acceleration
  • Study the relationship between torque and angular acceleration using T = Iα
  • Learn how to calculate tangential acceleration from angular acceleration
  • Explore the concept of resisting torque in mechanical systems
  • Investigate practical applications of moment of inertia in real-world scenarios
Mechanical engineers, physics students, and anyone involved in the design or analysis of rotational systems will benefit from this discussion.
Windwaker2004
A cylindrical fishing reel has a moment of inertia of I=6.22×10-4 kg·m2 and a radius of 4.44 cm. A friction clutch in the reel exerts a restraining torque of 1.34 N·m if a fish pulls on the line. The fisherman gets a bite, and the reel begins to spin with an angular acceleration of 66.5 rad/s2. What is the force of the fish on the line?
I would like to know if the proper acceleration to use here to calculate force would be the tangential acceleration. Also, when I use T = Fxr... does the value of F get subtracted from the force the fish is pulling with? I also can't figure out how to use the inertia in this because if I solve for mass using I = MR^2 ... that's the mass of the reel which makes no sense in using to calculate force. Anyway any help would be greatly appreciated! Thanks in advance!
You just work with angular acceleration.
The eqn to use here is T= Iα
You are given the values of I and α, so what is the torque providing this (angular) accln ?
You are given the resisting torque of the reel, so what must be the additional torque supplied by the fish ?
And finally, what must be the force giving this torque ?
Thank you so much for your help. I made it a lot more complicated than that method. I worked it out and got the correct answer. Thanks again!
9K
16K
