Calculating the Number of Permutations in the Symmetric Group of Degree 2n
  • Thread starter Thread starter Zurtex
    Permutations
The discussion revolves around calculating the number of permutations in the symmetric group of degree 2n, specifically focusing on permutations that can be expressed as two disjoint cycles of equal length. The original poster expresses a conjecture about the number of such permutations and seeks guidance on proving this conjecture.
  • Participants discuss the original poster's conjecture and explore methods for counting permutations, including the number of n-cycles in S_n and the implications of careful counting. There are questions about deriving known results and the relevance of certain theorems.
Some participants affirm the original poster's conjecture while suggesting that careful counting may suffice for a proof. There is an ongoing exploration of different counting methods and the complexities involved in extending these ideas to the symmetric group of degree 2n.
Participants note the challenge of working with material that is ahead of their current understanding and express uncertainty about deriving certain results. There is mention of homework constraints and the need to clarify definitions and assumptions related to cycles and permutations.
Zurtex
Hi, I need to work out the number of all permutations, [itex]\tau[/itex], in the form:
[tex]\tau = (\sigma_1 \sigma_2 \ldots \sigma_n) (\theta_1 \theta_2 \ldots \theta_n) \quad \text{for} \quad \sigma_i \neq \theta_j \quad \text{and} \quad \tau \in S_{2n}[/tex]
Namely 2 disjoint cycles of equal length in the symmetric group of degree 2n, letting [itex]\text{o}(\tau)[/itex] be the number of permutations of this form existing, then I have a good guess that:
[tex]\text{o}(\tau) = \frac{(2n)!}{2n^2}[/tex]
My first thought was to try and prove this inductively, but I’m struggling to come up with some kind of sum for [itex]\text{o}(\tau)[/itex]. Could anyone give me a hint or a starting step please.
Can you figure out how many ways to make an [itex]n[/itex] cycle in [itex]S_{2n}[/itex]?
How about the number of [itex]n[/itex] cycles in [itex]S_n[/itex]?
Your guess is right, now what you need to do is look back through your class notes or book and figure out what the instructor means when they ask for a "proof". I would think that a careful counting is enough.
Carl
Carl
This is part of a much larger problem, careful counting will be enough but I am unsure how to do that. We have been deliberatly set something that is ahead of what we know, my method for deriving that was somewhat strange and relies on things that I won't be able to prove until I've proven this (again more guesses).
There are (n – 1)! cycles in Sn right? I’m not sure how to derive that, I just remember it, I’m having to absorb a lot of new material in a very short time so I’ve kind of skipped over a lot of deriving in the books I’ve got out.
Frequently, the trick to counting something is finding a good way to describe the things being counted. Often, it involves not being distracted by what the things actually are! :smile:
Here's a counting proof for (n-1)! cycles in S_n:
We assume the cycles are for the integers from 1 to n. Without loss of generality, we assume that the cycle is described by a sequence of these digits starting with 1. For example, instead of describing a cycle by (231), we will instead use (123). By arranging for the cycles to always start with 1, we know that the number of cycles will be exactly equal to the number of these sequences of integers.
After the 1 which goes in the first position, there are n-1 choices for the second position in the cycle, then n-2 choices for the next, etc. So the total number of different cycles is (n-1)! .
Carl
Carl
Thanks, I had figured out it needed to be turned into a sequence but I wasn't sure how. But it seems more complex for the numbers of an n cycle in S2n. 1 might not be in the cycle...
In fact I'm not even sure that will be helpful, I was hoping to use a theorem I'd found but it only applies to subgroups and an n cycle isn't a subgroup in S2n is it? I mean it's not closed..
Hehe
Ignore my last post, just me being a little slow to catch on :shy:
Edit: Arghh I haven't quite worked it out, but I'm probabily close enough to firgure out the rest myself.
  • · Replies 100 ·
13K
  • · Replies 42 ·
12K
  • · Replies 20 ·
  • · Replies 175 ·
28K
  • · Replies 107 ·
21K
