Run Chat Client in C++: Easy Setup on Linux/Unix Servers
  • Context: C/C++
  • Thread starter Thread starter exequor
    Chat
The discussion revolves around the easiest methods to run a chat client written in C++ on Unix/Linux servers. Participants explore various aspects including setup, underlying protocols, and potential issues related to server-client communication.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants inquire about the specific chat client and the underlying protocol it uses, suggesting that clarity is needed for a more tailored response.
  • One participant mentions that if the chat client complies with open standards like Jabber, it would be advisable to use a corresponding server that supports those standards.
  • Another participant emphasizes the importance of ensuring that the client connects to the correct port on the server and that no firewalls are obstructing the connection.
  • A participant notes that the chat application is a simple server-client setup using Winsock, indicating a desire to expand its functionality.
  • There is a suggestion to consider the application layer and the implications of the chosen protocol on the server-client interaction.
Participants express varying levels of understanding regarding the setup process and the specifics of the chat client. There is no consensus on the best approach, and multiple viewpoints regarding the necessary steps and considerations remain present.
Some assumptions about the chat client’s functionality and the server environment are not fully articulated, which may affect the clarity of the discussion. Additionally, the discussion does not resolve the technical challenges faced by the participants.
Individuals interested in running C++ applications on Unix/Linux servers, particularly those focused on chat applications and network protocols.
exequor
What is the easiest way to run a chat client that was written in c++? Preferably for a unix/linux server.
Technology news on Phys.org
compile it and run it?
What is the chat client, and what underlying protocol do you want to use?
If it is based on an open standard then by all means use an open standard as your server..
Your question needs more clarity.
If you build a chat client that complys with the Jabber standards then use a Jabber server, however if you write your own protocol for your client, then write the Server app ensuring it complys with this protocol.
It is just a simple server that uses winsock, and a client to go with it.
You need to think below the application layer
If you have the server and the client then what is the problem? Assuming the client connects to the right port on the server and uses an agreed protocol then all you need to do is make sure you don't have a firewall in the way blocking either the incoming port on the server or the outgoing port on the client. Did you write the software yourself or is it someone else's and are you just having difficulties using it?
It is a simple application that we [a group] wrote. It is very simple now and we are going to expand on it. Currently it works when someone runs the server on their computer, but we want to run it on a webhost's server or a shell account, sort of like an ird daemon.
  • · Replies 29 ·
  • · Replies 39 ·
