The discussion revolves around calculating the change in enthalpy and entropy for 1 mole of silicon carbide (SiC) when heated from 25 degrees Celsius to 1000 degrees Celsius, using a provided specific heat capacity equation.
- Exploratory, Assumption checking
- Participants explore the relationship between heat capacity and entropy, referencing the integral form of entropy change. Questions arise regarding the assumptions of constant pressure and the absence of non-expansion work in the problem setup.
The discussion is active, with participants questioning the assumptions necessary for applying the equations. Some guidance is provided regarding the interpretation of specific heat capacity and the typical conditions assumed in thermodynamic problems.
There is an ongoing examination of the assumptions related to constant pressure and the nature of work done by the system, with no explicit resolution reached on these points.
