Classifying Amphoteric Oxides - Li_2O, BeO, P_4O_6, Cl_2O, etc.
  • Thread starter Thread starter dx/dy=?
The discussion revolves around classifying various oxides, specifically determining which among them are amphoteric, meaning they can act as both Lewis acids and bases. Participants explore the characteristics of specific oxides, including Li2O, BeO, P4O6, Cl2O, and others, and seek clarification on the criteria for amphoteric behavior.
  • One participant lists several oxides and notes which are known to be amphoteric, while questioning the classification of others.
  • Another suggests drawing Lewis structures to help determine if a compound is amphoteric.
  • A participant categorizes oxides into basic, amphoteric, and acidic, providing chemical equations for reactions involving these oxides.
  • There is a query about the specific requirements for a compound to be classified as amphoteric, focusing on electron pairs and orbital availability.
  • One participant notes that metal oxides are typically basic, while non-metal oxides are acidic, suggesting a review of reactions involving these oxides.
  • A later reply discusses neutralization reactions between acidic and basic oxides, providing an example involving MgO and SiO2.
Participants express various viewpoints on the classification of specific oxides, and while some classifications are agreed upon, there remains uncertainty and debate regarding others. The discussion does not reach a consensus on the criteria for amphoteric behavior.
Some participants reference the need for further review of chemical reactions and definitions related to amphoteric oxides, indicating potential limitations in understanding or application.
dx/dy=?
Hi all,
I was wondering if anyone could help me with classing the following oxides as AMPHOTERIC.
Ie) They act as both lewis acids and bases.
My textbook does not have a very thorough description.
Here's the list, with the ones I already know.
Li_2O
BeO
CO_2 -Only a Lewis Acid
P_4O_6
Cl_2O
Al_2O_3 -Amphoteric
BeO
SnO_2 -Amphoteric
Br_2O_7
PbO_2 -Amphoteric
Cheers for any help,
It will be much appreciated.
to get an idea, try drawing out the lewis structure
Basic: alkali metals, alkali Earth metals (except Be), and Tl
Amphoteric: Be, Al, Ga, In, Ge, Sn, Pb, As, Sb, Bi
Acidic: chalcogens, halogens, B, C, Si, N, P
Transitional Metals depend on oxidation state.
Basic:
Li2O + H2O --> 2LiOH
Amphortetric:
BeO + 2H+ --> Be+2 + H2O
BeO + H2O + 2OH- --> [Be(OH)4]2-
Al2O3 + 6 H+ --> 2 Al3+ + 3 H2O
Al2O3 + 3 H2O + 2 OH- --> 2 [Al(OH)4-]
SnO2 + 4H+ --> Sn+4 + 2H2O
SnO2 + 2H2O + 2OH- --> [Sn(OH)6]2-
PbO(s) + 2H+ --> Pb+2 + H2O
PbO(s) + H2O + 2OH- --> [Pb(OH)4]2-
Acidic:
CO2 + H2O --> H2CO3
P4O6 + 6H2O --> 4H3PO4
ClO2 + 2H2O --> 2HOCl
Br2O7 + H2O --> 2HBrO4
Thanks for the help both of you.
So if I draw a Lewis-structure to discern if a compound is amphoteric, then how exactly do I know,
Is it that the molecule requires a non-bonding pair of electrons to be a Lewis-Acid, and that it also requires an completely empty orbital to accept a pair of electrons, hence also being a Lewis-Base?
I mean, is that what makes a compound amphoteric?
Cheers again.
metal oxides are usually basic oxides, while those oxides of non-metals are acidic oxides such as carbon dioxide. You should review the equations in your text between the reaction of these oxides with water, and even a reaction of an acidic oxide with that of an basic oxide and compare it with the reaction of a strong arrhenius acid/base neutralization. Water for instance is amphoteric in a sense since it can be protonated (as a lewis base) and has a slightly basic arrhenius proton.
Ya for example you can have a neutralization reaction between an acidic oxide and a basic oxide to produce a salt:
2MgO + SiO2 --> Mg2SiO4
  • · Replies 19 ·
36K
