Finding a min gate input count realization of enabling logic ?
The discussion revolves around finding a minimum gate input count realization of enabling logic for a home security system using AND and OR gates and inverters. Participants are tasked with interpreting a truth table and the operational logic of the system, which includes multiple sensor inputs and a master switch.
  • Homework-related
  • One participant expresses confusion regarding the problem statement and seeks clarification on the inputs and their meanings.
  • Another participant suggests that there are seven input variable lines, including six sensor lines and the master switch, leading to 128 possible input combinations, and proposes two approaches to create the truth table.
  • A detailed description of the home security system's operation is provided, outlining the inputs (sensor signals and master switch) and outputs (alarm, lights, video cameras, call to police), emphasizing that all outputs should activate if any sensor detects an intrusion while the system is on.
  • Repeated requests for urgent help indicate a sense of urgency in finding a solution, with participants seeking hints or guidance.
Participants have not reached a consensus on the problem's specifics or the best approach to solve it. There are multiple interpretations of the requirements and no clear agreement on how to proceed with the truth table or logic realization.
There are missing assumptions regarding the definitions of inputs and outputs, and the operational logic may depend on how the truth table is constructed. The discussion does not resolve these uncertainties.
mr_coffee
Hello everyone, I'm confused on what they want me to do here:
it says:
Find a minimum gate input count realization of the enabling logic using AND and OR gates and inverters. Well This is my truth table i came up with, and the "enabler" is the M, the master switch( 0 secruit system on, 1 secuirty system off). Here is the picture: http://img145.imageshack.us/img145/6249/lastscan0oh.jpg any help would be great.
You do not fully state what your problem is. Can it be assumed that there are seven imput variable lines (the six "S" lines, and the enable M)? If so, then there are 2^7, or 128 possible input line combinations. That makes for a long truth table, but it isn't difficult to work with. There are two basic approaches to working with this. 1) Either you can put everything into a 128 combination truth table, or 2) for each desired output line, you can eliminate all inputs that don't pertain to it, and then make four truth tables, one for each of those desired outputs.
First, though you need to specify clearly what the inputs mean, and from this what input combination drives each of the outputs.
KM
A home security system has a master switch that is used to enable an alarm,lights , video cameras and a call to local police in the event one or more of six sets of sensors detects an intrusion. the inputs, outputs and operation of the enabling logic are specified as follows:
inputs:
Si, i=0,1,2,3,4,5 - signals from six sensors sets(0-intrusion detected, 1 - no intrusion detected)
M-master switch(0 -security system on, 1-security system off)
outputs:
A-alarm (0-alarm on, 1 - alarm off)
L-lights(0-lights on ,1-lights off)
V-video cameras(0-video cameras off, 1-video cameras on)
C-call to police(0-call off,1-call on
Operation:
if one or more of the sets of sensros detects an intrusion and the security system is on , then all outputs are on. otherwise all outputs are off
find a minimum gate input count realization of the enabling logic using AND and OR gates and inverters.
PLZ HEEEEEEEEEEEEEEEEEEEEEEELP
it is so vital for me to find the solution urgently ,
any hints are welcome,,,,
TNXXXXXXXXX
inputs:
outputs:
Operation:
TNXXXXXXXXX[/QUOTE]
  • · Replies 26 ·
17K
  • Sticky
9K
52K
