Solve the expression for n Є N
  • Thread starter Thread starter six789
    Expression
The problem involves solving the expression for n in the natural numbers, specifically the equation P(2n + 4, 3) = 2/3P(n + 4, 4), which relates to permutations and factorials.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the manipulation of factorial expressions and the potential for canceling terms. There are questions about the correctness of initial steps and whether cross-multiplication is appropriate.
Some participants provide guidance on simplifying the factorial expressions, while others express uncertainty about their own simplifications and the next steps to take. Multiple interpretations of the problem are being explored.
There is a focus on ensuring the understanding of factorials and permutations, with participants questioning their assumptions about the manipulation of these expressions. The original poster seeks confirmation of their work and clarity on the next steps.
six789
i just want to confirm if my answer is right...
this is the problem:
solve the expression for n Є N
P(2n + 4, 3) = 2/3P(n+4, 4)
this is my work:
(2n +4)!/((2n +4)-3)!) = (2/3(n+4)!)/((n+4)!)-4)!)
(2n +4)!/((2n +1)! )= (2/3(n+4)!)/(n!)
and i don't know wat to do next... should i just cross multiply it?
permutations
help me with this if my answer is correct...
help is appreciated...
help from anyone with this problem...
start canceling terms. if you have [tex]\frac{(2n+4)!}{(2n+1)!}[/tex] and you understand what factorial means, you can cancel all the factors in the denominator with some in the numerator. do this as well to the right side of your equation. then try to solve.
so you mean [tex]\frac{(2n+4)!}{(2n+1)!}[/tex] is same thing as writing as (2n+4)(2n+3)(2n+2)(2n+1)/(2n+1)?
uh, well the (2n+1)'s cancel out. but ya. that's how a factorial works. so do the same to other side and go.
correct me if I am wrong ok? I've try the other side... should you make the numerator 2/3(n+4)! to -2/3(n-4)! in order to cancel it from n(n-1)(n-2)(n-3)(n-4)?
no... i think you're missing something...
[tex]\frac{2/3(n+4)!}{n!}= \frac{2/3(n+4)(n+3)(n+2)(n+1)(n)(n-1)(n-2)(n-3)...}{n(n-1)(n-2)(n-3)...}[/tex]
so you're left with only [tex]2/3(n+4)(n+3)(n+2)(n+1)[/tex] cause you can cancel the rest out. do you see this?? does it make sense? this is what we did to the other side as well.
now i get gale... thanks so m uch, and it is clearer for me now...
what if you get like this... -24(2n+3)(n+4)(n+3) = 0...
what should i do to the -24? or it is just 0, then the value for n is just n=-2/3, n=-4 and n=-3?
well, I'm not really sure how you got that... its not what i get. what's your equation after you've simplified? i get something simple enough to multiply out and then combine like terms. then solve.
i got like (2n+4)(2n+3)(2n+2) = 2/3(n+4)(n+3)(n+2)(n+1)
then... 2(n+2)(2n+3)2(n+1) = 2/3(n+4)(n+3)(n+2)(n+1)
which is 4(2n+3) = 2/3(n+4)(n+3)
multiply it out and simplify, its just a quadractic.
  • · Replies 19 ·
  • · Replies 17 ·
