Prove Critical Damping: x(t)=A+Bt e^(-Beta t)
The equation x(t)=(A+Bt)e^(-Beta*t) represents the solution for critical damping in a second-order linear ordinary differential equation (ODE). To prove this, one must assume a solution of the form x(t)=y(t)e^(-Beta*t) and derive the function y(t). The relevant differential equation for critically damped systems is m \ddot{x} + c \dot{x} + kx = 0, where the characteristic polynomial reveals repeated roots, confirming the critical damping condition.
  • Understanding of second-order linear ordinary differential equations (ODEs)
  • Familiarity with the concepts of critical damping and characteristic polynomials
  • Knowledge of the physical parameters: mass (m), damping coefficient (c), and spring constant (k)
  • Ability to manipulate exponential functions in differential equations
  • Study the derivation of solutions for second-order linear ODEs with constant coefficients
  • Learn about the implications of repeated roots in characteristic polynomials
  • Explore the physical interpretation of critical damping in mechanical systems
  • Investigate numerical methods for solving ODEs, such as the Runge-Kutta method
Students and professionals in mathematics, physics, and engineering, particularly those focusing on mechanical systems and differential equations.
eku_girl83
Show that the equation x(t)=(A+Bt)e^(-Beta*t) is indeed the solution for critical damping by assuming a solution of the form x(t)=y(t)exp(-Beta*t) and determining the function y(t).
Is there a differential equation for the critically damped case that I can substitute x(t) and its appropriate derivatives into to solve for y(t)?? Hints, please! There are no examples like this in the text...
This is more of a ODE problem than a physics one as you have notice.
The differential equation for the free damping idealized spring:
[tex]m \ddot{x} + c \dot{x} + kx = 0[/tex]
For the case of critical damping the characteristic polynomial for this linear ODE indicates repeated roots. Well give it a try.
