4Cu + O2 --> What is the name of the compound ?
  • Thread starter Thread starter parwana
The discussion revolves around the chemical reaction of copper and oxygen, specifically focusing on the identification of the resulting compound and the stoichiometry of the reaction. Participants explore the oxidation states of copper and the balancing of the reaction.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant suggests that the product of the reaction is copper(I) oxide but expresses confusion about the reasoning behind this identification.
  • Another participant emphasizes the necessity of first writing and balancing the complete reaction before discussing the product.
  • A third participant proposes that the balanced reaction is 4Cu + O2 = 2Cu2O, leading to the conclusion that 2 moles of the compound are produced, questioning why it is copper(I) oxide instead of copper(II) oxide.
  • One participant explains that it is generally easier to oxidize copper to +1 than to +2, citing the lower enthalpy of formation for copper(I) oxide as a reason for its stability.
Participants do not reach a consensus on the balanced reaction or the identification of the compound, with multiple views presented regarding the oxidation states and the balancing of the equation.
The discussion includes assumptions about oxidation states and enthalpy that are not fully explored or defined, and the balancing of the reaction remains unresolved.
parwana
1. [1pt]
The below reaction gives one ionic compound as a product.
4Cu + O2 -->
An example of the correct answer format would be lead(II) nitrate note the space
Its going to be copper(I) oxide right, but I don't understand why?
Also How many moles of the ionic compound are produced for the above reaction , would it be 4?
First write and balance the complete reaction. There can be no discussion of the second part before you do this.
Isnt it
4Cu + O2= 2Cu2O
so it would be 2 moles, but why is it copper I oxide, not copper II oxide
It is easier to oxidize somethingto +1 (usually), than it is to oxidize it to +2. Taking that first electron away isn't so tough, but the second requires much more energy.
Also, Copper (I) Oxide has a lower enthalpy of formation than Copper (II) Oxide, so it is more energy favorable for copper to oxidize to +1 than go all the way to +2.
13K
