Hat current is needed to provide a modest 40 kN force? plug and chug
  • Thread starter Thread starter mr_coffee
    Current Force
The discussion centers on calculating the current required to generate a force of 40 kN using an electric train design that utilizes Earth's magnetic field. The correct formula for current is I = F/(L*E-5), where F is the force (40,000 N), L is the axle length (3.0 m), and E is the vertical component of Earth's magnetic field (10 µT). The calculated current is approximately 1.3333E9 Amps. Additionally, the power loss for each ohm of resistance in the rails is calculated using P = I^2, resulting in approximately 1.77778e18 Watts.
  • Understanding of electromagnetic force calculations
  • Familiarity with electric current and resistance concepts
  • Knowledge of the formula for power loss in electrical circuits
  • Basic understanding of the vertical component of Earth's magnetic field
  • Research the principles of electromagnetic force in electric trains
  • Study the effects of resistance on power loss in electrical systems
  • Learn about the applications of Earth's magnetic field in engineering
  • Explore advanced calculations for electric current in varying conditions
Engineers, physics students, and anyone involved in the design and optimization of electric train systems or electromagnetic applications.
mr_coffee
Consider the possibility of a new design for an electric train. The engine is driven by the force on a conducting axle due to the vertical component of Earth's magnetic field. Current is down one rail, through a conducting wheel, through the axle, through another conducting wheel, and then back to the source via the other rail.
a) What current is needed to provide a modest 40 kN force? Take the vertical component of Earth's field to be 10 µT and the length of the axle to be 3.0 m.
b) How much power would be lost for each ohm of resistance in the rails?
THe professor gave us the formula for this one and yet it didn't work, did I mess up somthing else?
He said for part a, use the following formula:
F = I*L*E-5;
I = F/(L*E-5);
I = 4000/(3*E-5);
I = 1.3E8
I don't know why its E-5 but i also tried E-6 and still didn't work...
and for part b he said to use
P = I^2;
But really I just need to find out why part A isn't working! Thanks! :bugeye:
F=iLB=i(3)(10E-6)
F=(30E-6)i
i=40000/(30E-6)=1.3333E9 Amps
This was the right answer for me...
and
P=i^2*R
i^2=(1.333E9)^2=1.77778e18 Watts
mr_coffee said:
I = F/(L*E-5);
I = 4000/(3*E-5);
[tex]40kN \neq 4000 N[/tex]
~H
[Edit] Sorry didnt see Schrödinger's post
