How to Solve for x in a MATLAB Function Using Given Parameters?
  • Context: MATLAB
  • Thread starter Thread starter atrid32
    Function Matlab
The discussion centers on creating a MATLAB function to compute the variable x based on given parameters W, k1, k2, and d. The user initially attempts to define x within an if/else structure but encounters an error due to the undefined state of x at the time of comparison. The correct approach involves evaluating x based on the independent variable W, leading to the formulas x=W/k1 for x=d. The solution emphasizes the importance of defining independent variables before making conditional evaluations.
  • Understanding of MATLAB function syntax
  • Knowledge of conditional statements in programming
  • Familiarity with mathematical modeling concepts
  • Basic grasp of variable scope and initialization in programming
  • Review MATLAB function creation and variable scope
  • Learn about conditional statements and their proper usage in MATLAB
  • Explore mathematical modeling techniques for defining dependent and independent variables
  • Investigate error handling in MATLAB to troubleshoot similar issues
Mathematics students, MATLAB programmers, and engineers involved in computational modeling who need to understand function evaluations and variable dependencies.
atrid32
Hi, i need to write function for the following.
W=k1x if x<d
W=k1x+2k2(x-d) if x>=d
Question is: Create function that computes distance x using the input parameters W, k1, k2, and d.
k1=10^4
k2=1.5*10^4
d=0.1
W=500 and 2000
so i get the formulas solving for x that are
x=W/k1 and x=(W+2k2d)/(k2+2k2)
but I don't know how to solve for x as I get error which says that x is not defined when i use if/else and i tried using for loop and got the same problem.
here is my code:
function x = spring (W)
k1=10^4;
k2=1.5*10^4;
d=0.1;
if x < 0.1
x=W/k1
else x >= 0.1
x=(W+(2*k2)*d)/(k1+(2*k2))
end
Any help please?
Hi,
I see the problem not with the code but with the concept of this calculation it self. If you took a look on what you have written it's obvious why doesn't it work.
How can you evaluate a function depending on the output of the function?
you say for example
y = 3 * x if y < 5
y = 5 * x + 7 if y >= 5
this conditions can't be on the dependent variable it can only be on the independent variable you can calculate it easily.
so y = 3 * x if x < 5/3
and y = 5 * x + 7 if x >= -2/5
I know that's are not mutual exclusive conditions. Which in fact what you are doing in first place?
but why MATLAB say this error?
review the code:
Code:
k1=10^4;
k2=1.5*10^4;
d=0.1;
if x < 0.1
see until this comparison you haven't made any evaluation for the x.
If your calculation are recurrsive - depend on the previous value of x -, then you can assume an inital value for x to make this comparison
That's all,
bye
