Calculating the magnetic field of 3 piece wire
The magnetic field at point P, located at the center of a half-circle arc formed by a wire carrying a current of 5.78A, has been calculated correctly. The radius of the arc is 0.0789m. The formula used, B = μ0*i/(2*π*R), yields a magnetic field strength of 1.14X10^-4T when the values are substituted appropriately. This confirms the accuracy of both the calculations and the formula employed.
  • Understanding of Ampère's Law
  • Familiarity with magnetic field calculations
  • Knowledge of the Biot-Savart Law
  • Basic proficiency in physics, particularly electromagnetism
  • Study the Biot-Savart Law for calculating magnetic fields from current-carrying conductors
  • Learn about the applications of Ampère's Law in different geometries
  • Explore the effects of varying current on magnetic field strength
  • Investigate the relationship between magnetic fields and electric currents in circuits
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations will benefit from this discussion.
GrassPuppet
Okay I need some verification that I did this problem right. If not then please tell me where I went wrong.
Given a long wire going into the page with current also going in the same direction and then making a half-circle arc along the plane of the paper to the left, and finaly conituing to make a straight wire. Find the magnetic field at P which is at the center of the arc (center of circle if the arc were a full circle). I'm given the radius of the arc and the current.
i=5.78A
R=.0789m
I used phi=Pi
I attached the formula I used and a poor drawing of what the wire looks like.
segment.View attachment arc.doc
I got 1.14X10^-4T
Yes, your solution is correct. Your formula is also correct - the magnetic field at P is given by B = μ0*i/(2*π*R). Plugging in the values you provided, you get B = 4π*10^-7 * 5.78/(2*π*.0789) = 1.14X10^-4T. Therefore, your answer is correct.
  • · Replies 20 ·
