Calculate Work Needed to Stop Rolling Cylinder
  • Thread starter Thread starter ViewtifulBeau
    Cylinder Work
The problem involves calculating the work needed to stop a rolling homogeneous cylinder, considering both its translational and rotational kinetic energy. The subject area includes concepts from dynamics and rotational motion.
  • Mixed
  • Participants discuss the kinetic energy associated with both the linear motion of the cylinder and its rotational motion. There is an exploration of how to account for both forms of kinetic energy in the work calculation.
Some participants have attempted calculations involving translational and rotational kinetic energy, but there appears to be confusion regarding the correct approach to combine these energies. Guidance has been offered regarding the need to sum both types of kinetic energy to find the total.
Participants are grappling with the definitions and calculations of kinetic energy for both linear and rotational motion, and there may be assumptions about the cylinder's properties that are not fully clarified.
ViewtifulBeau
A homogeneous cylinder of radius 30cm and mass 40kg is rolling without slipping along a horizontal floor at 2.4m/s. How much work is needed to stop the cylinder?
work = delta_KE in this case so oi figured .5 *40 * 2.4^2 = 115 J but this is not right, what should i do with the cylinder?
i still can not figure this one out.
Besides KE of the center-of-mass moving in translation (linear),
you also have KE of the extended mass moving AROUND the c.o.m.
KE_rotation = 1/2 I (omega)^2
i did this and found omega to be 8 rad/s and I to be 1.8 then i found the KE to be 57.6 this is now right either.
"Besides" the old linear KE there's now rotational KE, ALSO.
The total KE is the SUM : KE_linear + KE_rotation
  • · Replies 16 ·
  • · Replies 26 ·
