Momentum, Impulse, and Collisions
This discussion focuses on calculating the average force exerted on a baseball during a collision with a bat, specifically a 0.154 kg baseball that changes direction and speed upon impact. The initial velocity of the baseball is 50 m/s to the right, and it leaves the bat at 65 m/s to the left at a 30-degree angle. The average force can be determined using the formula for net force, which is the change in momentum divided by the change in time, specifically F = Δp/Δt. The components of the force must be calculated separately for horizontal and vertical directions.
  • Understanding of momentum and impulse concepts
  • Familiarity with vector components in physics
  • Knowledge of Newton's second law (F=ma)
  • Ability to perform calculations involving time intervals in physics
  • Study the principles of momentum conservation in collisions
  • Learn how to resolve vectors into horizontal and vertical components
  • Explore the relationship between impulse and force over time
  • Practice problems involving collisions and average force calculations
Students in physics, educators teaching mechanics, and anyone interested in understanding the dynamics of collisions and forces in sports contexts.
einahpets
How would I go about this problem? Any advice would be really helpful, please.
A bat strikes a 0.154 kg baseball. Just before the impact, the ball is traveling horizontally to the right at 50m/s, and it leaves the bat traveling to the left at an angle of 30 degrees about the horizontal with a speed of 65m/s. If the ball and bat are in contact for 1.75ms, find the horizontal and vertical components of the average force on the ball.
How would you include the concept of momentum in this problem, and is F=ma needed?
I could be wrong but I think you use net force = change in momentum/ change in time. F = p/t or F=mv1-mv2/t, and once you have the force you can find the x and y component.
you SHOULD treat the x and y components separately from the start.
Sum of F = ma is a special case of p_i + (Sum of F)dt = p_f .
  • · Replies 19 ·
