Driven, damped harmonic oscillator - with particular solution
The discussion focuses on finding the particular solution for a driven, damped harmonic oscillator described by the differential equation mx'' + bx' + kx = A1cos(wt) + A2cos(3wt). The user, Daniel, seeks assistance in deriving the particular solution using Lagrange's method of varying constants. The complementary solution is established by setting the right side of the equation to zero, but the challenge lies in addressing the non-homogeneous terms involving multiple frequencies. The proposed form for the particular solution is x_{part}(t) = C_{1}(t)cos(wt) + C_{2}(t)cos(3wt).
  • Understanding of differential equations, particularly second-order linear ODEs.
  • Familiarity with the concepts of driven and damped harmonic oscillators.
  • Knowledge of Lagrange's method of varying constants for finding particular solutions.
  • Basic grasp of oscillatory motion and the significance of frequency in harmonic systems.
  • Study the application of Lagrange's method of varying constants in detail.
  • Learn how to derive particular solutions for non-homogeneous differential equations with multiple driving frequencies.
  • Explore the behavior of damped harmonic oscillators under different driving forces.
  • Investigate the implications of resonance in driven systems and how it affects the solution.
Students and professionals in physics and engineering, particularly those focusing on mechanical vibrations, control systems, and differential equations related to oscillatory motion.
eku_girl83
Driven, damped harmonic oscillator -- need help with particular solution
Consider a damped oscillator with Beta = w/4 driven by
F=A1cos(wt)+A2cos(3wt). Find x(t).
I know that x(t) is the solution to the system with the above drive force.
I know that if an external driving force applied to the oscillator then the total force is described by F = -kx - bx' + F0cos(wt).
But in our case the driving force is A1cos(wt)+A2cos(3wt) so
F=-kx-bx+A1cos(wt)+A2cos(3wt).
Then our differential equation is mx''+bx'+kx=A1cos(wt)+A2cos(3wt).
This can also be written as x''+2Betax'+(w^2)x=A1cos(wt)+A2cos(3wt).
For the complementary solution, we set the right side of the equation equal to zero and solve for x. This is o.k.
However, I am having trouble with the particular solution. Can someone tell me how I find a particular solution for this? I can find the particular solution for x''+2Beta x'+ (w^2)x = A cos (wt), but what about the particular solution when the driving force is not A cos (wt), as we have in this case?
Any help GREATLY appreciated!
Use Lagrange's method of varying constants. That is assume that the particular solution to the nonhomogenous ODE is
[tex]x_{part}(t)=C_{1}(t)\cos\omega t+C_{2}(t)\cos 3\omega t[/tex].
Daniel.
