Red & White: Seeing the Wall Differently
  • Context: High School
  • Thread starter Thread starter nzahra_ghasemi
    Wall
The discussion revolves around the perception of color in a scenario involving two rooms illuminated by different colored light bulbs (red and white). Participants explore how the color of a wall (referred to as wall 3) appears differently depending on the light source and the observer's position. The focus includes concepts of light reflection, color perception, and the effects of illumination on perceived color.
  • Exploratory, Conceptual clarification, Debate/contested
  • Some participants explain that the apparent color of a wall depends on the light illuminating it, with red light making a white wall appear red and white light making it appear white.
  • One participant suggests that the question involves an adjacent side wall, indicating that the wall may be illuminated from both rooms due to an open door, leading to different perceptions of color based on the observer's position.
  • Another participant introduces the idea that the wall's texture could affect how light is reflected, potentially causing variations in perceived color based on the angle of observation.
  • There is a clarification that the original question did not mention the door, which adds complexity to the understanding of how light interacts with the wall.
  • Several participants express frustration with the ambiguity of the question and the need for clearer definitions of the scenario.
Participants do not reach a consensus on the specifics of the scenario, with multiple interpretations of how the wall is illuminated and perceived. There are competing views on whether the wall's color change is due to illumination effects or other factors like texture.
There are limitations in the clarity of the original question, particularly regarding the arrangement of the rooms and the role of the open door. The discussion also highlights the dependence on assumptions about light behavior and wall properties.
nzahra_ghasemi
there is two rooms in one of them ,i lit a red bulb and in the other room a white bulb when I'm in the red room i see the wall that is between these two room,red,but when I'm in the room with white light i see this wall white.
why?
Science news on Phys.org
A wall painted "white" reflects a broad spectrum of colors. When white light (a mix of all wavelengths) illuminates it, it appears white; but when red light illuminates it, it appears red. The apparent color of the wall depends on the light used to illuminate it.
Imagine this. Paint the wall "blue", meaning use paint that reflects blue light and absorbs other colors. When illuminated with white light, the "blue" wall appears blue. But shine red light on it and that red light will be absorbed. The "blue" wall will appear black.
key words: wavelength, reflection
pay attention ,what i said,there is two room and an open door between them,when I'm in the room whith red light i see this wall (painted white)between two rooms red and when I'm in the room with white light i see it white.i say why i don't see this wall still red be cause of the open door.
you didn't mention a door when you posed the question.
as posed, your question is essentially "why does a wall look red when illuminated with red light, but look white when illuminated with white light"
the reason, of course, is that the wall is reflecting whatever light you're shining on it.
but now you say there's a door in the wall. presumably it's open. so now you're asking how come the side of the wall facing the red light is still red.
the reason, of course, is that the white light isn't passing through the door only to make a sudden u-turn. in other words, that white light is not shining on the side of the wall in the red-lit room. so that side of the wall is only illuminated by the red light, and that's all that's getting reflected.
No, I think the question is regarding an adjacent side wall, not the center wall separating the rooms. S/he is saying that the side wall is illuminated from both rooms (because the center partition is open in that area), but you see the same section of wall as having two different colors, depending on where you look from.
The reason would have to do with the reflective properties of the wall. Texturing might cause it to reflect low-angle of incidence light rays back toward their source instead of into the next room. It may be easier to consider the effect of texturing if you make the texture big - say shoebox sized bumps on the wall. If you look at that wall at a low angle and shine a light from the same angle, the bumps will reflect light back to you, but they will also cast shadows. but since the bumps themselves block you from seeing the shadows, you'll only see the reflected light.
Ambiguity really gets to me. It breaks my brain.
ah cheghadr shomaha khengid,so I repeat my question
*(red light bulb)*
((room1))
wall(1)
-------------|wall(3) <---the wall between these two rooms |---------
wall(2)
((room2)) *(white light bulb)*
I light a red bulb in room 1 and a white one in room 2.
when I'm in room 1,I see wall 1 ,red,and wall 2,white,and wall 3,red.
when I'm in room 2,I see wall 1 ,red,and wall 2,white,and wall 3,white.
I want to know why the color of wall 3 change when i chang my position?
I repeat my question:
|((room 1))*red light bulb*
| wall 1
| v
|-----------------| < wall 3 |-------------------------------------------|
| wall 2
|((room 2)*white light bulb*
I light a red bulb in room 1 ,and a white bulb in room 2.
when I'm in room 1,I see wall 1 ,red,and wall 2,white,and wall 3,white.
I want to know why i see wall 3 in diffrent colors when i change my position?
  • · Replies 40 ·
  • · Replies 207 ·
16K
  • · Replies 22 ·
  • · Replies 23 ·
