Determining Current Flow in an Ideal Transformer
  • Thread starter Thread starter Infidel22
This discussion focuses on determining current flow directions in an ideal transformer using the dot convention. The user highlights confusion when applying the conservation of power formula, V1I1=V2I2, particularly in forward converters, leading to incorrect current direction assumptions. The conversation emphasizes the importance of understanding the winding direction relative to magnetic flux to accurately derive current directions in transformers.
  • Understanding of the dot convention in transformers
  • Familiarity with the conservation of power principle (V1I1=V2I2)
  • Knowledge of forward converter topology
  • Basic principles of magnetic flux and winding direction
  • Study the dot convention in detail for transformers
  • Research forward converter circuit analysis techniques
  • Explore tutorials on transformer magnetic flux and winding direction
  • Learn about power conservation in electrical circuits
Electrical engineers, students studying power electronics, and professionals working with transformers and converters will benefit from this discussion.
Infidel22
I am having some difficulty detertming the directions current should flow in an ideal transformer given a certain dot convention. My general understanding in the past was that you simply used conservation of power: V1I1=V2I2, thus if the sign of V2 is opposite of V1, then the sign of I2 must be opposite of I1. However, when attempting to analyaze a forward converter, I end up getting the current directions backwards.
Is there any simple pattern to follow when deriving current directions through an ideal transformer?
A tutorial on the "dot convention" used in transformers.
http://www.allaboutcircuits.com/vol_2/chpt_9/4.html
The current direction in a wire conductor (rather than transformer magnetic conductor) is affected by the 'winding direction' with respect to the magnetic flux.
  • · Replies 28 ·
14K
