How can you prove the N choose k formula without using a formula?
  • Thread starter Thread starter mattmns
The discussion focuses on proving the combinatorial identity for m, n ≥ 2: (m+n choose 2) = (m choose 2) + (n choose 2) + mn. The first proof utilizes the formula for combinations, specifically a(n choose k) = a! / ((a - k)!k!). The second proof, which avoids using this formula, suggests employing Pascal's triangle and counting 2-subsets from two disjoint sets with m and n elements. This approach highlights the relationship between combinatorial counting and arithmetic series.
  • Understanding of combinatorial identities
  • Familiarity with Pascal's triangle
  • Basic knowledge of arithmetic series
  • Concept of 2-subsets in set theory
  • Study combinatorial proofs and their applications
  • Explore advanced properties of Pascal's triangle
  • Learn about set theory and subset counting techniques
  • Investigate the relationship between combinatorial identities and algebraic expressions
Mathematicians, educators, and students interested in combinatorial proofs and set theory applications will benefit from this discussion.
mattmns
Hello.
I have the following problem: Show that for [tex]m,n \geq2[/tex],
[tex]\left(\begin{array}{cc}m+n\\2\end{array}\right) = \left(\begin{array}{cc}m\\2\end{array}\right) + \left(\begin{array}{cc}n\\2\end{array}\right) + mn[/tex]
by using the formula
[tex]\left(\begin{array}{cc}a\\b\end{array}\right) = \frac{a!}{(a - b)!b!}[/tex]
and algebra. Prove it again without using this formula.
The first part was quite easy, but I am not sure how I could solve the second (bold) part without using a formula. Am I supposed to use a definition or something of that nature? I just am not seeing it, any ideas would be appreciated. Thanks
You could use Pascal's triangle and note that the third item in row N is the sum of the items in the third diagonal with values [itex]1+2+ \cdot\cdot\cdot \+ N-1[/itex] which is just an arithmetic series.
Take two disjoint sets, one having m elements and the other having n elements, and count the number of 2-subsets of their union in two different ways.
