At which part of the height of the building the balls collided?
The discussion revolves around a physics problem involving two balls: one thrown from the top of a building and another thrown upward from the ground. Participants explore the conditions under which the balls collide and the height at which this occurs, considering factors such as initial velocities and acceleration due to gravity.
  • Homework-related
  • Some participants note that the velocity of ball A is twice that of ball B at the moment of collision (VA = 2*VB).
  • One participant formulates equations for the motion of both balls, considering constant acceleration and the effects of gravity.
  • Another participant claims to have found that the collision occurs at 2/3 of the building's height, assuming ball A has no initial velocity.
  • Some participants express uncertainty about the correct interpretation of the problem, particularly regarding whether ball A is dropped or thrown.
  • There is a discussion about the equations of motion used and the constraints involved, including the relationship between the heights traveled by both balls and the total height of the building.
  • One participant recounts confusion stemming from a translation issue regarding the problem statement, which affected their understanding of whether ball A was dropped or thrown.
  • Another participant emphasizes that the problem is analogous to two objects moving towards each other with different velocities and accelerations.
Participants generally agree on the mathematical approach to the problem but disagree on the interpretation of the initial conditions and the resulting height of the collision. The discussion remains unresolved regarding the correct height from which the collision is measured.
There are limitations regarding the assumptions made about the initial velocities of the balls and the potential impact of translation errors on the problem's interpretation.
Lisa...
Help Needed Asap! Please!
Hi!
I need to solve the following problem before tomorrow.. otherwise I'll be in big trouble. :rolleyes: I've already discussed it with classmates, but they also don't know how to handle it. Please help me!
Ok this is the question:
A ball A is thrown off a building and at the SAME time a ball B is thrown up from the ground. When both balls hit each other, they move in OPPOSITE direction and the velocity of ball A is twice the size of B. At which part of the height of the building the balls collided?
So VA= 2*VB when they hit.
Both balls traverse some distance in the same time T (to be determined) because they are released at the same time, and they collided at the same time.
Now ball A is thrown (or dropped ?) and is accelerating down, while ball B is thrown up and decelerating, and the rate of acceleration g and rate of deceleration is -g.
Can you write an equation for each ball, remembering v(t) = at + vo, and x = 1/2 a t2, assuming constant acceleration, where a = g or -g depending on acceleration or deceleration.
Hi!
Thank you for your help! I found the fraction where the collision took place to be 2/3 of the buildings height, assuming ball A had no initial velocity. Is that correct? (by the way: that wasn't mentioned in the problem, but if I use a v0A I can't find a proper fraction (without an initial velocity in it).
I haven't had time to work through it, but I believe that is correct.
I was going to look at this problem this evening.
Thanks a hell of a lot! You are doing a great job helping people out with their homework! Keep up the good job ;) !
Just curious, what equations of motion did you use?
There are 4 equations/relationships here.
Two equations for position or height of ball A and ball B, and two equations for velocity.
There are two constraints. VA(T) = 2*VB(T), where T is the time of contact assuming a reference time of t=0.
And height of building H = hA + hB at t=T, they meet at approximately the same location - actually their CM's are separated by rA and rB. hA is the distance A travels to meet B at hB. You can find either h and the proportion hB/H.
Well I'll show you what I did to get to the answer of 2/3 and could you please tell me if this is the correct way ? :wink: o:) :
First I formulated two equations for the velocity of ball A and ball B at a certain time t, so:
v(t)A= gt
v(t)B= v0B-gt
The balls collide when v(t)A=2 v(t)B so when gt= 2v0B-2gt .
From this equation the time t when the collision occurred is obtained:
gt = 2v0B - 2gt
3gt= 2v0B
t= 2v0B/3g
The height ball A has traveled from the top of the building is given by
x(t)A= 1/2 gt^2
And the height ball B traveled from the ground is:
x(t)B= v0B t - 1/2 gt^2
Since the collision occurred at a time t= 2v0B/3g the height from the ground where it happened is obtained by substituting t= 2v0B/3g in the x(t)B formula:
x(2v0B/3g)B= v0B (2v0B/3g) - 1/2 g(2v0B/3g)^2=
((2v0B^2)/3g)- (1/2g((4v0b^2)/9g^2))= ((2v0B^2)/3g)- ((4v0b^2)/18g)= ((12v0B^2)/18g)- ((4v0b^2)/18g)= ((8v0b^2)/18g) =((4v0b^2)/9g)
Ok so now I only need to know the height of the building, which is given by the height ball B traveled from the ground till the collision occurred (x(2v0B/3g)B) + the height ball A traveled from the top of the building till the collision (x(2v0B/3g)A) occurred. So h= x(2v0B/3g)B + x(2v0B/3g)A. x(2v0B/3g)B was already calculated, so:
x(2v0B/3g)A= 1/2 g(2v0B/3g)^2 = (1/2g((4v0b^2)/9g^2))= ((4v0b^2)/18g)=((2v0b^2)/9g).
The height of the building h= ((2v0b^2)/9g) + ((4v0b^2)/9g)= ((6v0b^2)/9g)
The fraction of the height of the building where the collision occurred is given by x(2v0B/3g)B / h = ((4v0b^2)/9g)/((6v0b^2)/9g) = 2/3
(seen from the ground!, because x(2v0B/3g)B = the height where the collision occurred measured from the ground)
Now this last thing was actually my biggest doubt. I've talked to many fellow students who thought 1/3 was the height where the collision occurred seen from a ground perspective, because they thought: ball A has twice the velocity of ball B when they meet, so ball B had traveled 1/3 from the ground and ball A 2/3 from the top of the building, therefore the collision occurred at 1/3 of the height of the building above the ground... I'm not very sure what's the correct answer... What do you think?
well fration works out to be 2/3 h from the ground
lets assume the distance ball be travels befor collision be D which is equal to
D= (4(v0b^2)/9g), ...1
and then the distance traveled in same time by ball a is
H-D = (2(v0b^2)/9g)...2
from 1 and 2
H = (6(v0b^2)/9g)
fraction...would be D/H which works out be 2/3, that mean ball B has to climb 2/3 of the height of the building.
that also means that ball A has to drop to 1/3rd of the hieght of the building befor both ball collide.(doesn't matter where u are lookin from)
Thank you! I already thought so! :D
The equations of motion of the balls are correct, assuming ball is dropped, and the rest appears to be OK. :smile:
Btw concerning the usage of an initial velocity for ball A: today I heard from a few fellow students that the problems we had to solve were translated from English to Dutch (I live in the Netherlands) and my teacher translated the phrase 'the ball was dropped' as 'de bal is gegooid', which literally means 'the ball was thrown', because 'gegooid' mean thrown and 'gevallen' means dropped.
Ohhh I hate my teacher for doing that! It caused me to overwork till dawn! Anyways thanks again for your help!
Yeah, but it made you think! :biggrin:
Actually that is a nice problem. It's a bit like two trains coming at one another in opposite directions, possibly starting at different times, perhaps with differences in initial velocity and acceleration.
Here the key was knowing about the acceleration and the time.
  • · Replies 36 ·
