Calculate Molar Fraction for Freon in a 60 Gal Tank - Step by Step Guide
  • Thread starter Thread starter simonak
    Fraction
The discussion focuses on calculating the molar fraction of Freon (CF2Cl2) in a 60-gallon tank containing pure nitrogen (Azote) at 36.2 psig and 24.2 °C. The user has successfully calculated the number of moles of Freon as 7.51161 mol but requires the volume of nitrogen to determine the total number of moles for the molar fraction calculation. Two methods for finding the number of moles of nitrogen are proposed: using volumetric weight and the ideal gas law (PV=nRT). The molecular weight of nitrogen is established as 28.0 g/mol.
  • Understanding of molar fractions and their calculations
  • Familiarity with the ideal gas law (PV=nRT)
  • Knowledge of molecular weights, specifically for Freon (CF2Cl2) and nitrogen (Azote)
  • Basic concepts of gas properties under varying temperatures and pressures
  • Research the ideal gas law and its applications in real-world scenarios
  • Learn about the properties and calculations involving molar fractions
  • Explore the volumetric weight concept and its relevance in gas calculations
  • Investigate the physical properties of Freon and nitrogen, including their molecular weights
Chemists, chemical engineers, and students studying thermodynamics or gas laws will benefit from reading this discussion, particularly those involved in gas mixture calculations and refrigerant properties.
simonak
Hi,
here's the problem :
A 60 gal tank contain pure Azote at 36,2 psig and 24,2 °C. We add 908,25 g of freon (CF2Cl2) that evaporate completely. If the temperature of the tank is 8,2 °C :
a) What is the molar fraction of the freon.
I've made some calculation, but it always result that I need the volume of the Azote to continue.
Calculations :
The molar fraction is the (number of mol for the freon) / (total number of mol). I found the number of mol for the freon = 7,51161 mol.
Now I need the total number of mol. So I need the
(number of mol for the freon) + (number of mol for the azote) / (Molar weight of freon) + (Molar weight of azote).
The only thing that is missing is the (number of mol for the azote). And I found 2 ways to find it
1) volumic weight * Volume
2) PV=nRT ===> n = PV/RT ==> M = m/n ==> m = n*M ...
In each case, I don't have the volume of the azote so I cannot continue
"Azote" is an archaic name for nitrogen, MW = 28.0.
