Can scientists see either atoms or molecules?
  • Context: High School
  • Thread starter Thread starter David Mayes
    Atoms Molecules
The discussion centers around whether scientists can visually observe atoms or molecules, exploring the definitions of "seeing" in a scientific context, and the methods used to image these small entities. It encompasses theoretical, experimental, and conceptual aspects of visibility in science.
  • Some participants suggest that scientists can "see" atoms indirectly using techniques like scanning tunneling microscopy (STM) and that certain man-made molecules can be observed using classical methods.
  • Others argue that "seeing" at the atomic level is limited by the wavelength of visible light, and that techniques such as X-rays or electron beams allow for imaging of smaller structures.
  • A participant questions whether DNA molecules have been seen or if they are merely theoretical models, prompting further discussion on the nature of imaging at the molecular level.
  • Some participants note that STM images represent electronic charge distributions rather than direct visual observations, leading to a distinction between imaging and seeing.
  • There are claims that while STM can produce images of atoms, it operates differently from optical microscopes, which directly scatter light.
  • A participant presents an analogy about developing theories based on indirect observations, emphasizing the limitations of direct visibility in understanding atomic and molecular structures.
Participants express differing views on the nature of visibility at the atomic and molecular levels, with no consensus reached on whether true "seeing" occurs or if it is merely a representation of effects. The discussion remains unresolved regarding the definitions and implications of "seeing" in scientific practice.
Limitations include the dependence on definitions of visibility, the indirect nature of imaging techniques, and the unresolved mathematical and conceptual aspects of observing atomic structures.
David Mayes
If not, what is the smallest object/entity we can see?
Seeing in science has a special meaning.
Scientist have seen atoms with indirect way,such as STM.And there are a group of man-made molecule that can be seen with classical method.With the help of modern detecting technology,quark may be the next to "be scaled".
"Seeing" quarks would be difficult, since they don't occur outside of hadrons. There have been electron scatering experiments indicating 3 scattering sights in protons.
In general, if you mean "seeing" as by visible light, then there is a limit - things smaller than a wavelength can't be "seen". However by using X-rays or electron beams, scientists can create images of things that are much smaller.
Excuse me to expand this topic.
Seeing in some degree defines the area of science in my eye.Things which can be detected, measured by the physical device are significative.
Originally posted by mathman
In general, if you mean "seeing" as by visible light, then there is a limit - things smaller than a wavelength can't be "seen". However by using X-rays or electron beams, scientists can create images of things that are much smaller. [/]
Has anyone ever seen a DNA molecule, or is that a theoretical model{a graphical representation}..?
I accept knowing and describing atoms via effects, I was just curious if they've ever been seen@molecules for that matter?
The diffraction limit is indeed given by the wavelength (devided by 2, but thats' not important). However, this only applies to far-field optics! In near-field optics items with a size of a few nanometer can be resolved using visible (say 400 nm) light...
Yes, scientists can image actual atoms and molecules, such as DNA. It is not just a model. It is, however, a graphical representation. A microsope images the subject and displays what it "sees" on a screen. It's every bit as real as the electron micrographs you see of the close up shots of ants or pollen.
I was under the impression that we can't see atoms, that we could only create models that best reflect the effects of atoms.
No, you can image the actual atom. It's not just a model. Look up scanning tunneling microscope. It's not quite the same as "seeing" with your eyes, hopefully you already understand that, but it's still imaging the actual atoms.
Ok thanks.
I'll do some googling:smile:
Originally posted by Ambitwistor
What an STM is actually imaging is the electronic charge distribution of the atoms...
http://www.nobel.se/physics/educational/microscopes/scanning/
And this means that the graphical reprenstations of atoms@molecules are based on the effects of atoms, IOW, no-one can take either an actual photograph or can look into a microscope and immediately see either an atom or molecule...is this correct..?
Well, STM's are microscopes, and they can certainly produce images of atoms (which you could turn into photographs, if you wanted). But they don't work the way an ordinary optical microscope does, which scatters light directly off of atoms into your eyes. STMs are more indirect.
Ok thanks for your help Ambitwistor.
There's AFM, which uses a very fine cantilever to "see" molecules in the same way a blind person reads braille.
To your main question
The answer is no. You can not really "see" the very things that make up the cosmic realm of the microscopic regions. We use various methods to test the "reactionary likelihood" of certain theoretical constructs to see whether or not it is the case that certain notions, hold up to whatever degree they can. What this means is, that you must have a collected base of assumed notions about the overall nature of various concepts such as an electron, proton, photon, and the what not, and all these notions can with enough ingenuity be tested to a degree.
Take the following analogy: You are blind, hence, you really have no real sight of what distance is between one thing and an another. Saying so however does not mean, that you can't develop a theory "about what distance is" by doing somehting like, maybe finding a wall, and throwing a ball at it, to see if it makes a sound when it hits it, and to get a feel for how long it took for the ball to make the sound. You do this maybe with different object, at different measures that you may count with your steps, and "feeling" the differences in sound, and the what not. For example, you can feel with your hand the differences in texture between a rubber wall, and a brick, and associate these textures with what you have found about when you threw things against a wall. From this way of doing things, then, you can safely assume that something that feels rubbery seems to bounce, while something hard like a brick, just seems to hit the ground without any real bounces.
When you do something like this, you can inevitably develope your own theories that hold some kind of validity until you find something that invalidates your theories, or until new pieces of data arrives, that throws out of whack some aspect of your theories, thus requiring a slight modification of your theory to account for those factors that were not originally a part of the main theory/theories. A theory is technically a representative modal of something that you feel to somehow be an explantory answer to a particular question/equation. It is a sketch of a thought, a thought that seems to explain an observation, or experience.
When, we speak of gravity, and we think of Sir Isaac Newton, all that we are doing is using his modal of descriptive thought to account for why things seem to fall down when they are tossed into the air. His theory of how the size of an object seems to create a gravitational pull seems to explain then the idea for what is otherwise known as "gravity." But his theory in the strictest sense can not be proven to be true. It may vary well be the case that something else explains why things fall to the ground, and it has nothing to do with the size of an object which in turn may create a pulling force on another object that might be of a smaller size. But because his modal is better than nothing, we accept it as perhaps a valid description for why there is such things as "gravity." Theory of gravity then, is something that you can't really see, but you have notions that lend themselves to somekind of supportive base. Notions like motion, and how motion seems to be affected, and the what not.
In relation to atoms, electrons, and the what not, i think you have to get into chemstry, some math, and some physics, in order to create modals of predicability concerning "the nature of" certain elements. Once you develope these theories of the natures that govern various elements, you can then move on to creating the means necessary to justify the assumptions that you take as being descriptive modals for what something is.
To give you another analogy, let's say, you want to know if it is true that fire can burn things. Well, do that, you actually have to set certain things on fire in order to see the result. Based on your observations, you make generalisations, like water boils, at such and such a degree, or that it takes such, and such degree to melt metal.
When it comes to the microscopic realm, similar methods of testability is more or less applied. But over all, you can't really see the things you believe in when you get to the microscopic realm. You simply have to rely on guess work based upon what you already know so far about certain experiments. The theory of radioactivity, and magnetism must be variables to account for, and ultimately test, and fit into some aspects of your whole system of workable theories, or speculative modals.
Thanks Hwarfare.
A sizeable but easy to read response, well done.
I am pleased
that i have made sense to you. Another member of this post however thinks that i am the dumbest member this forum has had.
But i am pleased you found what i said intelligable.
As near as I can figure out, your idea is that because we can't see and feel electrons. etc. with our own eyes and fingers, therefore all our constructions are suspect. There "might be" some other theory to account for things falling than Newton's* (or Einstein's).
As Johnny Carson said on a famous occasion, yes, and the universe "might be" created by a chicken named George.
* Didn't Newton see and feel the Apple? He could see, if not feel the Moon and others had compiled its regularities, going back to the Babylonians who had very accurate results. This enabled him to calculate its rate of acceleration toward the Earth and compare that to the rate of acceleration of the apple. The only unknown was the distance of the Moon, and this had to be inferred from various observation - i.e. from looking at the Moon and measuring angels, and of experiencing eclipses and measuring times. What part of all this is fictive?
this is getting tiring
I did not suggest that there weren't grounds/reasons for various constructs. No where have i said that.
Maybe you need to read what i said.
