Determine whether the series converges
  • Thread starter Thread starter Shay10825
    Series
The discussion revolves around determining the convergence of an alternating series, specifically whether it converges conditionally, absolutely, or diverges. The original poster mentions using the alternating series test and expresses uncertainty about verifying the condition \( a_{n+1} \leq a_n \).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the steps needed to prove the inequality \( a_{n+1} \leq a_n \) and explore various methods, including the ratio test and d'Alambert's method. There are questions about the applicability of these tests and the nature of conditional convergence.
The conversation is active, with participants offering different approaches and questioning the assumptions underlying the convergence tests. Some guidance has been provided regarding the use of the ratio test and the conditions for absolute convergence.
There is an emphasis on the need for generality in proving inequalities, and participants note that \( n \) is positive in the context of the series being discussed. The original poster's uncertainty about the steps and conditions for convergence reflects the complexity of the problem.
Shay10825
Hello. The question says: “determine whether the series converges conditionally or absolutely, or diverges. The series they gave me is an alternating series so I used the alternating series test. The alternating series test has 2 parts. The 1st part says the limit as an goes to infinity must be 0 and an+1 <= an, for all n. I know how to do the 1st part but I don’t know how to find out if an+1 <= an. The answer in the back of the book says that it converges absolutely.
[img=http://img392.imageshack.us/img392/9695/calchw46zm.th.jpg]
Thanks
Are you a girl?
to show that [itex]a_{n+1}\leq a_n[/itex], just...
1. Write out the equality you want to prove:
[tex]\frac{n+1}{(n+1)^3-1} \leq \frac{n}{n^3-1}[/tex]
2. Manipulate the hostile inequality as you would an equation to reduce it to a simpler form for which you know the "value of thruth" (i.e. wheter it is true of not). For exemple, you would write
[tex]\frac{n+1}{(n+1)^3-1} \leq \frac{n}{n^3-1} \Leftrightarrow ... \Leftrightarrow 0\leq n[/tex]
which is true, hence the inequality of origin is true.
Yes I'm a girl:smile: . How did you know?
Can I plug in numbers and see if it is less than a_n because that equation gets really messy?
I tried to simplify it and I got:
(n-1)/[(n+1)(n+2)] <= 1
If I simplified correctly then where do I go from here?
why don't you try d'Alambert's method or the ratio test?
What's d'Alambert's method ?
If you're dealing with absolute convergence of a series, you should start with
[tex]\sum_{n=2}^{\infty} |\frac{(-1)^{n} n}{n^{3} - 1}|[/tex]
If this series of absolute values converge then the series absolutely converges.
If that doesn't work you should apply the ratio test
[tex]\lim_{n \rightarrow \infty} |\frac{a_{n+1}}{a_{n}}| < 1[/tex]
can you find out if it conditionally converges by the ratio test?
Conditional convergence basically means the series converges but its series of absolute values diverges. With the ratio test you can find absolute convergence and divergence.
If I did the ratio test would I have to include the (-1)^n?
of course.
If it is not an alternating series then can it have conditional convergence?
I said a series, i didn't especifically meant Alternating series, so what i said above applies to all.
ok thanks. I think I understand it now.:smile:
I wanted to test my "girl handwritting recognizing" skills. :cool:
You can't plug in the numbers. It has to be perfectly general (i.e. true for every n, or at least for all n greater than a certain N). The inequality may seem messy at first but once you get rid of the denominators, things start canceling out very quickly from side to side of the inequality and you're left with 4n >= -1, which is true for all n.
and n can only be positive right?
Look at your sum: n goes from 2 to infinity. So yeah, n is always positive. Sometimes, n will run from 0 to infinity. In that case, n is not always positive. But the important thing is that there exists an N such that for n>N, the inequality [itex]a_{n+1} \leq a_n[/itex] holds. Do you see why only this "weaker" condition is necessary, and not "for all n"?
If you have a rational expression for a_n where degree(numerator) < degree(denominator) IMo it's generally easier to show the result by dividing top and bottom by the polynomial which dominates in the denominator for large values of n.
[tex] a_n = \frac{n}{{n^3 - 1}} = \frac{1}{{n^2 - \frac{1}{n}}}[/tex]
[tex] a_{n + 1} = \frac{1}{{\left( {n + 1} \right)^2 - \frac{1}{{n + 1}}}}[/tex]
So you want to show that a_n >= a_(n+1).
The numerators are equal if you write them as I did above. If you can show that the denominator of a_(n+1) is greater than the denominator of a_n then you've shown the result. Considering that n is natural number it's not hard to do so. You should be able to finish it off.
Hmm...reminds me of how I forgot to finish off a question on my exam with [tex]...\forall n > \max \left\{ {N,N'} \right\}[/tex].
sorry 'bout that :p
